My Headlights got fogged
I probably didn't screw them in properly so my headlight got fogged. Only one though. Anyone have an idea and a solution? Will popping it in the oven work?
On a low humidity day (if possible), partially remove the bulb, use hair dryer to heat up the lamp housing. With the housing warm, plug in the bulb. This will produce low pressure inside the housing with less moisture.
Warning: Use proper care not to over heat.
Quick (partial) alternative: Turn on the lamp and use that to heat the housing.
Salim
Salim
myLexRX
03-26-18 11:52 AM
