Removing rear brake rotor problem
Old 08-30-14, 07:05 PM
Cabral255
Cabral255's Avatar
Default Removing rear brake rotor problem
Trying to get off rear brake rotors on 2003 rx300 but I think the E brake is keeping it from coming off. Any advice?
Old 08-30-14, 08:34 PM
carguy07
carguy07's Avatar
You can adjust the shoes in through the hole with the rubber plug in it, Are they loose and moving around but just hung up on the shoes? If not they may just be stuck to the hub.
Old 08-31-14, 12:03 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,103 Likes on 992 Posts
If I recall it right, turn the drum (neutral and e-brake released ,,, make sure the other wheels are on ground and chocked) till the round hole is at 6 O'clock position. Put the vehicle in part. Use a flat screw driver to move the cog (star nut) to lower the shoes.
The holes on the rotor are slightly larger than the studs. Try spinning the drum. If you can spin the drum then you have successfully broken the bond and you should be able to remove the drum.
Salim
Old 09-01-14, 05:28 AM
Z07
Z07's Avatar
Are you using at least one (works faster with two) bolts in the machined holes to push/pull it off?
8mm x1.25
CPMD
03-27-23 04:27 PM
co4wheel
GX - 1st Gen (2003-2009)
03-06-16 11:34 AM
Tchan1
Suspension and Brakes
07-28-10 02:08 PM
trhs75
09-21-09 08:46 AM
shikbas
12-22-08 05:25 PM
Quick Reply: Removing rear brake rotor problem
