1999 RX300 AC problem
Old 07-03-14, 08:27 PM
jerwong
jerwong's Avatar
Originally Posted by salimshah
The question is do you trust their diagnosis?
If you do then it is all about parts and labor. Shop around to get a more competitive quote.
If you have the skill, tools and know how, the work can be done at home. Lexus requires a certain amount of oil at various places.
When you pick low milage vehicles you should expect problems with AC system, exhaust (cats etc) and various rubber parts. Oh check the date on the tires too. You may have good tread but the age can deteriorate the rubber.
Salim
Is there any reason you expect problems with AC/exhaust/rubber specifically with low mileage vehicles?
Old 07-04-14, 08:41 AM
salimshah
salimshah's Avatar
Things wear down with use, but never the less all things go back to their natural state (quote). Seals run dry if they dont get their lubrication (AC -system) .... in winter you run A/C once a week. Bushings/tires/belts face stress in one spot and develop a memory/shape. When they are moved infrequently they tend to rip up.
The major bye product of hydrocarbon combustion is moisture steam). That steam stays in the exhaust system. Cars rely on heat of the exhaust to prevent condensation. Low milage based on brief distance driving usually has worst exhaust.
Then there are other factors like exposure to UV if the vehicle has not been garaged.
Salim
Old 07-04-14, 11:01 AM
jimsRX300
jimsRX300's Avatar
I just fixed this today on my 2003 RX300 AWD
I replaced the compressor and changed the expansion valve.
The expansion valve is located on the DRIVERS SIDE of the vehicle. It is surrounded by a glued on THERMAL BLANKET. It must be torn off. I replaced mine with one from Home Depot's air conditioning and some zip ties.
The GAUGE CLUSTER must be removed. The EXPANSION VALVE is held on by 2 4mm Allen Head bolts. The additional 2 bolts must be removed from the evaporator to get the whole thing out. I also replaced the O-Rings with new.
2 hour job. AC is fine now.
tiguy99 (03-14-20)
Old 07-04-14, 02:19 PM
salimshah
salimshah's Avatar
I hope you did not cut any corners in evacuating and holding vacuum tests.
Salim
Old 07-05-14, 04:02 PM
jimsRX300
jimsRX300's Avatar
Nope, I let it evacuate while I changed out the right hand differential output seal.
If say I let it evacuate for a good 2 hours at least. Probably overkill.
Holds vacuum, air is still cold today. I didn't let it sit but 20 minutes. It still held full vacuum, good enough. This thing is 11 years old and on it's way out.
gvcenter54
12
07-28-14 04:10 AM
BeginnerIS
IS - 1st Gen (2001-2005)
06-29-11 07:09 PM
TRDmike
Performance & Maintenance
04-02-10 02:59 AM
RE agent
GS - 1st Gen (1993-1997)
08-24-09 09:53 PM
Quick Reply: 1999 RX300 AC problem
