Drive it or tow it: P1346 after timing belt
I posted earlier that a mechanic (actually my mechanic's assistant) changed my timing belt and I had an issue b/c he dented the oil pan. The mechanic fixed the dent and I drove home. After my post about the oil pan that evening, I took my RX out the following morning and the check engine returned. Scanned it as P1354 and googled it with timing belt - certainly appears the timing belt is off a tooth. The mechanic agrees that is almost definitely the problem. I'm taking it in but want opinions if I should tow it or drive it. The mechanic is 20 miles away. Hard to say if the RX feels OK - it's either not exactly right or it's my imagination b/c the check engine is on. The check engine light is solid and not flashing. The mechanic thought it's OK to drive.
And from now on no more assistants.
Laurensv
06-17-18 09:42 PM
