High pitch squeak at idle that goes on and off
Old 03-19-14, 11:16 AM
pingwrx
pingwrx's Avatar
Default High pitch squeak at idle that goes on and off
Just recently our 2001 RX300 with 85K developed a squeak at idle, it normally appears when the engine is warm and it sounds like a belt squeak, however when listening to it, a click of a switch of some kind in the engine compartment (thermostat, heater, alternator, a/c) will eliminate the squeak...then hear another click and the squeak comes back. The click is turning something on and off, not sure what...kind of like an A/C going on and off, and the squeak is tied to this going on and off. All belts, timing belt and water pump was replaced at 67K. Any assistance would greatly be appreciated.
Old 03-19-14, 12:14 PM
bob2200
bob2200's Avatar
I think the first thing to suspect is the accessory drive belt. Possibly the tension wasn't correctly set when it was replaced. I think I recall reading on this forum that it should be OEM-branded.
Old 03-19-14, 12:37 PM
salimshah
salimshah's Avatar
Check the accessory belt tension. [Adjustment is on the alternator]
Salim
LateNyta
08-02-13 02:02 PM
2jznosht
Performance & Maintenance
19
04-30-13 06:02 PM
adreano17
11-29-11 02:15 PM
robsotelo
11-11-11 02:20 PM
jimbo22s
Maintenance
12
12-07-04 08:24 PM
Quick Reply: High pitch squeak at idle that goes on and off
