99 RX300 keeps blowing AC and INT fuses
Old 08-24-13, 10:19 AM
greenRX300
greenRX300's Avatar
Default 99 RX300 AC Blower no loger working
My 99 RX300 recently blew a fuse for the AC blower so I replaced it. It worked for a day then stopped. I tried another fuse, but now it will not come on at all.
Is there a realy someplace that I can change or am I looking at going under the dash and swapping out the blower motor or blower control unit ?
Thanks, Chet
Old 09-03-13, 06:51 PM
greenRX300
greenRX300's Avatar
Well I found the solution to the AC blower not working. It ended up being the Blower motor control module. Pretty easy to change, 1 screw and a plug is all that holds it in place. Its kind of nestled behind some of the duct servos and other stuff so you need to wiggle it a bit to get it out. They are however expensive ($126 to $300) depending on where you shop. I scored a used Denso one for $75 from ebay that worked just fine though.
Chet
Old 09-03-13, 10:38 PM
salimshah
salimshah's Avatar
Thank you for sharing.
The controller is not hermetically sealed. When mine blew out ... I lost control of the speed. I looked at some pictures of the controllers being sold on the bay and decided to pony up for a new one.
It seems like a part that fails after number of years.
Salim
johnkread
05-06-19 06:22 PM
lexus99gs4
03-20-19 05:59 AM
gemmons
08-25-17 01:24 PM
Jayson
02-02-17 04:42 PM
ep9716
SC- 1st Gen (1992-2000)
08-27-09 10:09 AM
Quick Reply: 99 RX300 keeps blowing AC and INT fuses
