questions with 310,000 miles/ receipts
I just brought this car for a teenager to drive. Codes tell me a coil pack is bad #5. I got one off of Ebay and It DOA( I Switched the coils to #2)now the code reader says #2. New issue.
In park its at 700- 900 rpm everything looks good. When I put it in drive and cut the AC on it drops to about 500 rpm. Now would a bad alternator make RPM's drop that low or running on 5 cylinders do the same ? Back ground: I do all the maintenance on my F 250 diesel (212,000 miles)and an 04 Expedition. I posted on the over 200 mile thread and this is where I'm at. Oh the car was parked for 9 mouths before I got IT. I have almost the full maintenance history. I'm going to a local parts house to get a new coil. I think I can Keep this thing going,with out a major transplant.
i paid less than $1000.00 for the car.
Got a new coil. CEL are no more. After a short drive every thing looks good , except the temp gauge is running a little over half way. Is this normal? in South Carolina heat 90'.
Changing plugs.
PVC valve.
and cleaning ICV tomorrow
mpg on 25 trip was 18.5
310,000 and oil leak at engine and trans
bax
Changing plugs.
PVC valve.
bax
That is close to what it was running. OK on the front bank, near the radiator, there is a hose maybe CCV going to the intake is showing some weeping at the cover. And PVC on the back left looks to weeping. my diesel does this. What should I look for? Remember 310,000 miles.
Bax
Bax
On a separate note, please share some photos of the RX, as I would love to see what one looks like with double my mileage.
Thanks and welcome to the club!!!
Jim
Jim
I have a new issue. After sitting for a few days the car starts fine but the gas pedal is hard to press, I mean like I thought it was stuck. Its still a little hard to press after a short drive.
Is this normal or can I put some lube or grease on a spring, cable....?
Here are a few pics Harrier.
Bax
Bax
I would open the hood and twist the butterfly shaft and release the cable. You may like to take the the other cable (cruise control) off the wheel too. This would isolate the cables from the butterfly. Now check by hand if the butterfly is sticking or one of the two cables. If the cable is frayed, then replace it.
Use a dry graphite to lube the cable. Oil and grease attract dirt and will give you trouble in the long run. WD40 is not the right lube.
If the butterfly is sticking or binding, then you need to take off the air intake and use an appropriate cleaner. Check and make sure it is safe for RX. Not all carb cleaners are safe. You may have to hold the butterfly partially open to get the spray on the other side.
Last of all, sticky/binding throttle is a safety hazard. Please work on it with urgency.
Salim
Salim
So I cleaned the butterfly's in the throttle body. That was it. Thanks Salim.
I also cleaned the IACV while I had the breather box out. I thought I had screwd something up because, when I started the car the RPM's where at Like 1200 RPM. But after it warmed up the RPM dropped back to normal. It run's a lot better now. Great DIY section.
I have a few more bugs to work out that I'll post about but Thanks Again for the help.
I also changed the front seats with ones a got from a salvage yard.
Bax
Bax
Alright I have a new Problem. Today after a short drive I noticed a whine in the engine bay. I'm looking around and see the harmonic balancer has a slight wobble. And the main belt is leaving residue on the alternator. I'll post a pic tomorrow when the light outside is better.
Do harmonic balancer's go bad? And is this a maintenance item?
Bax
Bax
They absolutely go bad!
At certain engine speeds the torques imparted by the cylinders are in sync with the vibrations in the crankshaft, which results in a phenomenon called resonance.
This resonance causes stress beyond what the crankshaft can withstand, resulting in crankshaft failure.
Any pulley can go bad. Replace yours and change that belt ASAP.
There is one Toyota/Lexus model that has a recall (or tsb) regarding main pulley. It is hard to examine it in there so you will have to take it off. If the thing breaks when the engine is running, it will cause some serious damage. Keep the hood closed when engine is running to protect your head/face.
Salim
Salim
Update. So I changed the harmonic balancer and it looks a lot better but the alternator pulley is making a little noise so I'm taking it to a local shop for a rebuild. The housing looked pretty bad from sitting all those months and a rebuild will not hurt.
Just a note on the harmonic balancer that was chore to the bolt get off at first. I sprayed it several times with PB Blaster and waited an hour or so and that thing came off with ease. My impact wrench didn't even stall. PB Blaster is handy stuff.
Next on the list door actuators 3 of them including the rear hatch. And a spare key.
Bax
Bax
Bax
Bax
Salim
