rear sway bars
rear sway bars
i already looked on the search section. is there a link that gives information? my mechanic says the rear driver's side bump clunk is due to sway bar issues. he suggests to replace rear bars and bushings on both sides. there are lots availabe on e-bay. question: is there a difference between the length of the upper and lower bar? are bushings already installed on new bars, or is that usually separate? does the exhaust have to be removed to get at the passenger side bars, upper and lower? are any special tools needed? is there any trick to removing and replacing these? any other suggestions?
Look on JC Whitney
