Advice needed on jacking engine for RX300 timing belt change
Hi guys,
Need to jack engine up in order to change the timing belt and was wondering about the where and how to do this. From what I can see I need to raise the engine about 4 inches in order to remove some metal block that is more or less in front of the water pump. Do I need to undue the front engine mount bolt?
I have seen the youtube videos where people jack the engine up under the oil pan but the thought of this makes me VERY nervous - is this the right way?
Hi guys,
I read about the need to jack up the engine slightly to clear a bracket to remove the water pump. I have not done it, so I can only go bye on what I read. Maybe some one who did replace the water pump can confirm. How many inches?
Salim
Salim
No jacking needed. If you ever need to jack the engine for some other reason, just use a large block of wood (such as 2X8X10) under the pan and you won't have any problem.
Thanks for the replies.
I am 100% sure that you have to jack engine up the bit I'm trying to remove can be seen at 5:30 on the following video:
I just crapping myself that I'm gonna damage something by jacking so that's why I wanted advice. And yes I was going to replace the water pump while I was down there doing the timing belt that's why I need to remove this darn thing.
To get the long bolts out without breaking the end off, if you need them out to replace a W/P, just double nut 'em good and tight and turn the inside nut to get 'em out and back in.
If you do go the route of double nut, please publish the size of the nut-threads in the DIY section.
Thanks
Salim
Thanks
Salim
nestor32
RX - 1st Gen (1999-2003)
38
02-01-15 09:12 PM
