Can not pull out my antenna
According to Salim's instruction, I did:
1. Set ignition switch to LOCK
2. Remove Antenna Nut. (outside of RX.. where the rod goes in)
3. Have some one to hold/catch the antenna rod to prevent damage.
4. Hold AM, FM Buttons and trun the ign to ACC. The rod would extend fully and will be released.
The rod will not fully released. It is hold inside the slot firmly. I tried hard to pull it out, but failed. I don't know if I operated correctly, but I did repeated 4 for several times. Any suggestion please, thanks.
It could be the time to remove the whole motor assembly. The above instructions work when things are behaving.
Some one posted instructions on how to get the motor out.
Salim
Salim
Lexson
SC- 1st Gen (1992-2000)
09-20-02 10:00 PM
Lexson
12
09-18-02 06:35 PM
