A/F sensor? Search brought up too many opinions.
I know this has been asked a million times and multiply the answers x5.
Of course the issue I am having happened to me while I was driving it and not the wife.
Her daily commute to work is primarily highway driving with a lot of stop and go. She also refuses to use the cruise control when she is able. End result 19.1 mpg
Wife and kids flew out to California to meet with family for the week so I decided that I would park my car and drive hers.
My commute to work is a 52 mile round trip with very little stop and go and avg speed is 65-70 mph using cruise control.
Well wouldnt you know it. The mpgs dropped dramatically from the 19.1 to 15 mpg.... Tires are properly inflated. Not running the a/c or heat nor the heated seats.
We either run 93 shell or bp on every tank.
Check engine light is intermitent and code suggests to replace a/f meter. I am sure they are the originals and they are pushing 160k.
My experience with these sensors when failing usually comes with the following symptoms.
The obvious , lower mpgs. Dying at idle and hesitation. Is it possible for the sensor to be bad and only causing poor mpgs???
I know this is a long drawn out thread and I truely appriciate you reading this. However, the answers that I have browsed during my searches came up with way too many opinions on what to do.
Thanks again guys.
Thanks again guys.
I am up in the air on what to do. At $4.20 a gallon , it may be worth it to just replace both sensors. Because at the rate we are using fuel now, the sensors would pay for themselves. If in fact that is they are the culprits. Being broke sucks!!!!
Thank you for the suggestion. I do aprriciate that.
IF you do end up deciding you are going to replace the sensor(s), get them on Amazon. They have been as low as less than $80. but I think are up closer to $100. ea. now. Don't even think about anything but Denso sensors. They will have the Denso part # on them but are the exact same sensor as Lexus will want $225.- $250. ea. for. I must ask why you use premium fuel? I know the manual gives you the option and I don't know what the fuel in In. is like but my DIL's "99 RX has over 165K mi. on now on absolutely nothing but 87 oct. (reg.) fuel. I am the mechanic for the car and can tell you it runs like a top on it. Her mother has an '07 Lexus RX and complains about the fact it's the 1st. car she's had that requires Premium fuel at 20 cents a gal. more. She has about 85-90 K mi. on it now so is thinking about trading.
I work at amazon so I will be able to get a small discount anyways on them. I found one of the sensors last night on amazon for $50 or so and it was oem. I check the reviews and it was the correct part..
I need to do something soon. I was driving this because the MAF on my car has crapped out on me. When it rains.......
The sensor that you are looking at on Amazon is the O2 sensor that is after the cat, not the A/F sensor that you need.
If the CEL comes on and you go into limp mode, it will run like crap and get awful gas mileage.
What opinions are you conflicted about?
Thanks to hypers link today on the diagnosis videos , I did take notice about a possible issue on the ICV
When I start it up , it stays at 1500 rpm until I put it in gear, I am just in a panic right now.
73 miles driven and just barely above a half tank
I have read it could be the MAF , ICV which could trigger the light. If I recall correctly P0171 is for the MAF.
That should be easy to check. The 2 black wires are the heater wires and you should be able to do a simple continuity check or an Ohms check and determine if it is bad. it shouldn't make any difference whick way (direction) you check because it's just a simple heater. When one went bad on my DIL's RX after I replaced it I took a die grinder and narrow cut-off blade and cut it apart. It was easy to see the broken heating element. When the CEL is on, if it shows continuity or Ohms then the problem could be elsewhere.
