2000 rx300 awd/lights issues
My instrument guages lights/console lights radio etc/cielings lights/flicker when i turn on the headlights..why ? is that so ?
my clock does not keep the correct time even been set and when the key is remove,why ?
what is the best battery and tires for my truck ?
And can i change the timing belt and water pump by myself ?
i would like to replace the console/guages lights/door/glove box lights with a different color led lights how do y accomplish that and with that sizes bulbs
thanks
thanks
Sounds like our battery is on it's way out. You can get it load tested to make sure, but get it replaced ASAP.
What type of automotive experience do you have? A timing belt job is not for the faint of heart. There are a few video's on youtube regarding this particular engine's timing belt which you can watch to get an idea of what's involved.
WOW, finnally i change out my sparks plugs ,my mechanic recomd lexus oem plugs DENSO IRIDIUM....but lexus wanted $10.33 each..went to AUTOZONE got them for $6.99 each plus rebate 2.00 each/
i use the bosch iriduim plugs......should i see any differenace in proformance..? due to type used or is all plugs the same and how long should they last ?
woow, now should i remove them and go with the OEM ? ...but so far the car starts
thansk for the info
thansk for the info
But, if you've already installed them, keep them installed. It's not worth the effort to redo the rear plugs.
Mobvet
Performance & Maintenance
03-18-18 12:27 PM
