New to Lexus and forum!! Got a question....
#46
You can look here, but you can do a search here on homelink and you'll get a lot of hits. I have used the procedure in the manual and it has always worked for me. Sometimes reading what others have done helps.
https://www.clublexus.com/forums/is-...t-to-work.html
#47
I was holding the safety door open on a 440V outlet so that the guy from the welding supply store could test voltage many years ago. He didn't even touch his 2 probes together, just got a little too close because I was watching them. That 440 jumped the small gap and an M80 had nothing on that juice when it escaped. Scared the B'Jesus out of us and we couldn't hear for a little while. Didn't have a lot of hair on our arms (til it got up the courage to grow back) or a whole lot of eyebrows either.
I've never been afraid of much of anything, but I can't stand electrical shocks, or snakes, and I'm betting you have an adequate supply of both in Ok.
By the way, if you do send some of that "juice", send it UPS. Ought to give that UPS guy a story to tell his grandkids!
#48
#49
Ya know what BO, you make sure and keep that stuff in a proper container. Don't go just stuffing it in your pocket and walking out with it. I'm pretty sure it would burn more than a hole before you made it to the door!
Got the RX out of shop and it runs good. The cam seal was leaking a little. So far so good. STILL CANT GET HOMELINK PROGRAMMED!!!!!!!!!!!!!
Again, I appreciate everyones help here! It is EXTREMELY useful
David
#50
Ive read and read.....tried and tried......cant get it to work. My problem is the actual homelink in the visor. I am VERY confident that once I get the visor programmed, I can do the rolling code(my chevy trk has same feature). I cant get the visor to "learn" the hand held factory genie remote. I have done everything I know and this dam$ thing WONT work. I cant give up. This is not going to beat me. I cant let it go.........they make meds for this dont they?
#51
#52
There are some brands of remotes that do not work as expected. One brand only sends out a short burst (if you keep the button pressed, it only transmits for first few seconds). By the time the RX gets to the transmitted frequency, the sending unit has quit transmitting. The trick to learn is to apply steady bursts from the transmitter and hope that the RX would be scanning the frequency the transmitter is sending out.
You can also verify, that the RX is capable of learning by borrowing a transmitter of another brand from a family member or a friend.
Salim
Salim
#53
Working for who I do, pics float around of thieves attempting to steal copper WHILE IT'S HOT! I guess they are so doped up they don't care or realize its hot. They aren't pretty. Flash burn is not good.
#54
Salim
Salim
That my friend, is an EXCELLENT idea! Thank you
#55
IT WORKED! We tried my mother-in-laws opener(for her unit) and it took immediately. So then we knew it worked and that the problem was our openers. I took the wireless opener(that you hang on the outside of your house) off and held it up to the visor and WHAMO BAMO!!!!! IT WORKS!!!! Thanks for all the help and suggestions!
David
David
