Old 12-16-14, 12:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
transmission noise whine
Old 12-03-11, 02:15 PM
emitchum
emitchum's Avatar
Default transmission noise whine
is this terminal or will a flush extend life? if you listen the oddest sound is from P>R then there is a hesitation before it goes into D. this is a .wav attachment about 30 seconds long to give you an idea
File Type: zip
Old 12-04-11, 08:46 AM
thomas1
thomas1's Avatar
DO NOT do a flush, Have the pan dropped and change filter and refill fluid...A flush will be the kiss of death. During that process if the pan is full of metal, than your tranny is toast. No sense in wasting further money. If the fluid and pan is relatively clean, than maybe something else is going on.
Old 12-04-11, 02:35 PM
emitchum
emitchum's Avatar
thanks thomas1
i made a trip (not in the rx300) to autozone and got a filter kit and 4 quarts of castrol atf that meets lexus specs and a few ounces of lubeguard, sounds good now. the filter was black but the magnets were free of shavings but they did have heavy sludge on them. this car has 155,000 miles. i used a half quart of the used atf to bring the stick up to full. if this tranny lives i will change the filter at around 180,000
Old 12-04-11, 03:24 PM
hypervish
hypervish's Avatar
I suggest doing one more drain and fill in about 100 miles.
Old 12-04-11, 05:59 PM
emitchum
emitchum's Avatar
sounds like a plan. actually i was thinking, did i run those three bolts up that hold the filter in place? so my doubt got the best of me and i got to do it all over again. it is a good thing, they were finger tight
Old 12-04-11, 08:09 PM
thomas1
thomas1's Avatar
The suggestion for another drain and fill is what we do to get the fluid cleaner, The tranny actually holds about 8 to 9 qtrs so we do several drain and fills in a short period to get a more pristine fluid. I personally recommend a fluid change every 15k miles or once a year.
Old 03-23-12, 07:15 PM
rvess68
rvess68's Avatar
How did that work Out for ya
Old 03-23-12, 07:33 PM
emitchum
emitchum's Avatar
thanks for asking rvess68. drove the car a couple of thousand miles and did a drain and fill. the transmission is quiet and working great at 164,990 miles. we had priced a rebuild and it was $2750. This was kind of a reality check for me. This has kind of prompted me to do all the PM on the car as opposed to going to the garage somewhere. Tire rotation, brakes, belts, hoses, oil changes are all done at home now. Thanks for having forums to get good advice.
alchemist
01-09-14 05:29 PM
USMCLexus
07-14-10 10:31 AM
LS400_96
02-28-09 09:29 PM
mac187
GS - 1st Gen (1993-1997)
08-26-08 12:10 PM
Quick Reply: transmission noise whine
