rear rotors ?
Old 10-01-10, 07:42 AM
wvuguy
wvuguy's Avatar
Default rear rotors ?
I replaced front rotors and pads on my 99 RX300 with 142k miles. There was a vibration while braking both in pedal and steering wheel. Well the steering wheel vibration is gone but there is still vibration on the pedal and rear of the car followed by noise when braking. I am guessing I need new rear brakes. They seem pretty rusted. Any suggestions? Thanks.
Old 10-01-10, 02:41 PM
sktn77a
sktn77a's Avatar
Possibly - could be worn front suspension components (bushings), too.
Old 10-03-10, 06:45 PM
wvuguy
wvuguy's Avatar
It happens only when applying brakes so I am guessing its the rotors. Now a humming noise comming from front passenger side when turning left. Possibly bad bearing. I am getting tired of fixing this car!
Old 10-04-10, 10:08 AM
Gomer1
Gomer1's Avatar
Could also be tires.
Old 10-04-10, 12:03 PM
artbuc
artbuc's Avatar
Better than getting tired of a new car payment! Good-luck.
Old 10-06-10, 06:15 AM
wvuguy
wvuguy's Avatar
You are right about being better than about a new car payment. I have driven new cars but haven't enjoyed as much as I enjoy driving in RX.
I remember last year in snow the ABS will not kick in when tires with slipping. The ABS/Check engine light is not on. Could it be a problem with ABS causing pulsation in brake padel? How do I make sure ABS is working? Thanks.
Old 10-26-10, 06:32 AM
wvuguy
wvuguy's Avatar
I changed the rear rotors and pads last week and that fixed the vibration. I noticed the back side of the rotors was badly warped. The caliper pins were sticking. One of the pins had a torn dust boot so I had to regrease the pins and put new boot in. Also I ended up stripping a badly rusted caliper braket bolt on the right side. I had to cut out the head of the bolt to pull the caliper braket and rotor out. Once the braket was out, I was able to put it on vice grip and turn the remaining of the bolt with a pipe wrench.
When I was changing the front rotors, I had a hard time getting them off the hub due to rust. Suprisingly, the rear ones came off with a few blows of hammer in the center near the lug studs. It took me about 3 hours to get the job done but the brakes feel great now.
Old 10-26-10, 09:05 AM
salimshah
salimshah's Avatar
Do you wash the uderside after exposure to elements like snow/mud/salt etc?
Salim
Old 10-26-10, 09:58 AM
Carver
Carver's Avatar
Yea Texas, I don't think my car has ever seen salt. I put Brembo rotors on about 4 years ago that are zinc coated, still shiny!
Old 10-26-10, 12:13 PM
wvuguy
wvuguy's Avatar
Salim,
I have owned this car only for about 14 months. This car was in Pittsburgh before which gets quite a bit of snow. So most of the rust is pre-existing. I do wash underside frequently during winter months.
Slvr surfr
08-15-14 07:26 PM
Slvr surfr
Wheels, Tires & Brakes Forum
08-13-14 10:09 PM
tbilisi79
07-23-12 03:25 AM
Lexus082
Suspension and Brakes
12-27-10 12:53 PM
brian_ka7
10-23-08 08:04 PM
Quick Reply: rear rotors ?
