99 RX 300 rear hatch
Old 06-22-10, 01:04 PM
ericrx300
ericrx300's Avatar
Default 99 RX 300 rear hatch
My wife's RX300 rear hatch broke today. She tried to open it, heard some snap and now it won't open. Does anyone have any info regarding the parts associated with the rear hatch handle and latch
thanks in advance
Eric
Old 06-22-10, 02:01 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Eric, I had the latch assembly replaced on my '99. Mine did not break like yours but the handle was soft and would not unlatch easily. I listed the parts the dealer replaced below and they are still valid. You might need more but at least this can give you an idea. Maybe give one of the vendors here a call. Good luck.
6935048010 lock assy, back door (quantity 1)
6979033020 control assy, back door (quantity 1)
6777112010 retainer, door trim (quantity 3)
6777130060 retainer, door trim (quantity 2)
Old 06-22-10, 02:06 PM
ericrx300
ericrx300's Avatar
Thank you. I appreciate it.
Old 06-22-10, 08:11 PM
ericrx300
ericrx300's Avatar
it's just the pull handle. The plastic tab that pushes on the release lever snapped off. easy and not so costly repair I imagine
Old 07-23-10, 10:02 AM
rkd2412
rkd2412's Avatar
Default Hatch handle replacement instructions????
Same thing happened to me. I went to a recycle parts place for Lexus and bought just the hatch handle.
I have the carpet panel off, but now need directions from there. Can anyone help me out, please????
Can't live without the hatch,
Thank you,
Rachel
Last edited by rkd2412; 07-23-10 at 10:05 AM. Reason: added quote from the wrong thread
Old 07-23-10, 10:27 AM
ericrx300
ericrx300's Avatar
it is relatively easy. i assume you have the carpet off and can see inside the hatch with all the wires and what not?
ok at this point you need to get a socket wrench and remove I believe there were 3 or four nuts. You are actually removing the entire trim piece where the hatch release sits. Detach all the wire harnesses too. One nut is kinda hard to get at as i recall because it sat behind the rear wiper motor.
At that point the entire trim piece falls off. Replacing the hatch release is a matter of removing the two nuts holding the old one, putting in the new one and then reattaching the trim piece.
Took me 10 minutes total.
Old 07-24-10, 12:50 AM
rkd2412
rkd2412's Avatar
Thank you so much Eric!!!
I hope to get to this this weekend!
Rachel
Old 07-24-10, 08:41 AM
salimshah
salimshah's Avatar
Received 1,006 Likes on 909 Posts
Rachel
Keep your phone-camera handy and post a DIY.
Salim
Old 05-12-21, 01:26 PM
JabobJeff
JabobJeff's Avatar
Default Here's the Fix!
bareyb
GX - 1st Gen (2004-2009)
58
09-25-21 09:56 AM
Dyslexi
01-15-17 09:57 AM
BlackRX300
01-07-05 03:44 PM
slowtan
08-29-03 08:58 PM
Quick Reply: 99 RX 300 rear hatch
