RX300 knock sensor replacement DIY
Old 12-14-13, 08:17 PM
  #106
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
Originally Posted by lexusknock
Hey I recently replaced mine but now oppose to just one sensor being bad both are now saying they are bad any suggestions
Did you buy OEM knock sensors from a reputable place?
Recheck the connector and make sure you hear them snap close.
Salim
Old 07-13-14, 08:57 PM
  #107
av8rga
av8rga's Avatar
Check engine light is back on. It has been coming on intermittently last year or so, but now it's on solid. Had the codes read yesterday - P0330. What the heck?! I changed both of these and the harness 3.5 years/40k miles ago. When I changed them the first time, both tested Ok, which always raised my curiosity of whether they were actually the problem.
Four situations IMO:
1. The engine is really knocking. Sensors are doing their job and something else is wrong like timing or?... I never hear anything in fact I'm always impressed how smooth she runs with 150k
2. Wiring from sensor harness to main ECM isn't right. Bad ground, bad signal etc.. Guess I could jump all of it If I knew the pin sequence.
3. Bad ECM. Anyone have a loaner?
4. Bad knock sensors. Highly doubt it since they are relatively new and the ones I removed tested Ok.
Gotta get the fixed once and for all. Emission won't pass and as we know, this code shuts down the transmission overdrive
Thanks for any help. Tim
Old 07-14-14, 03:18 AM
  #108
carguy07
carguy07's Avatar
Just a thought: https://www.clublexus.com/forums/rx-...ck-repair.html
Old 01-16-15, 07:46 PM
  #109
kantgitit7
kantgitit7's Avatar
Thanks a million Salimshah,took my time broke it down in about 1.5 hours, going to change rear valve cover gaskets and plugs why it is easier to access from this tear down.
Old 03-01-15, 09:48 AM
  #110
Quang12345
Quang12345's Avatar
Just want to add. Whenever remove the hidden aic hook bolt, get a longer bolt and put it back with a spacer. So that you can use a wrench to install it or remove it next time. I also added a longer ground and mount it with easier access place.. Thanks
Old 05-09-15, 08:34 PM
  #111
av8rga
av8rga's Avatar
Originally Posted by carguy07
This works. Beats knuckle busting, back breaking, down to the gut of the engine knock sensors and harness swap. After all that, my engine MEL'd the same codes 3 years later. Factory parts... If you do decide to do all this work, swap everything you can at that level being plugs, hoses, and left/right valve cover gaskets. If your covers aren't leaking yet, they are either new or about to leak. Then do the above hack.
Tim
Old 05-14-15, 09:01 PM
  #112
gazi001
gazi001's Avatar
Originally Posted by av8rga
Lower manifold removed. I found it easier to lift out of the way and keep everything connected. I cleaned the injectors also.
How do you clean the injectors?
Old 05-15-15, 09:23 AM
  #113
matts6887
matts6887's Avatar
Tim
I would agree here. Doesnt make sense not to do all the extra stuff like plugs, valve covers, etc while the top part of the engine is torn apart.
Old 05-25-15, 03:19 PM
  #114
gazi001
gazi001's Avatar
Default How to replace Knock sensor Videos
I replaced the Knock Sensors, By pass hose, Harness, Manifold gaskets and clean all fuel injectors few days ago. I made this video for our members.
Old 05-25-15, 07:59 PM
  #115
salimshah
Forum Moderator
salimshah's Avatar
Gazi:
Please add your diy to an existing thread (if it exists). If not please add a link to the DIY sticky to your new thread.
To release the pins of the cowl, take a small socket and shove it over the pin. The socket size should match the pin and as you push it on, the spread on the pin is squeezed and the pins come out super easy. [I use 1/4 SAE socket]
Salim
Old 10-11-15, 06:23 PM
  #116
Pzindy
Pzindy's Avatar
Default hose clamps for bypass hose
I am into this, and having a very hard time re-using the old spring clamps. Pliers keep slipping off, and I am getting frustrated.
The new hoses did not come with clamps. Do you suggest buying clamps from the dealer, or are there acceptable aftermarket alternatives? My internet searches seem to indicate that worm drive clamps are not a good idea.They sure would be easier to install though.
Old 10-11-15, 11:41 PM
  #117
salimshah
Forum Moderator
salimshah's Avatar
Regular pliers do not work well as they form a "v" which tends to slide off as you squeeze. Slip joint pliers work lot better as they keep the squeezing force perpendicular to the clamps.
Slip joint pliers look like:
http://www.homedepot.com/p/DEWALT-10...4427/206173773
Is you bye pass leaking or bulging. Since the hose is flexible, you can push it out of the way.
Salim
Old 10-12-15, 06:23 AM
  #118
Pzindy
Pzindy's Avatar
Originally Posted by salimshah
Is your bye pass leaking or bulging. Since the hose is flexible, you can push it out of the way.
Salim
My old bypass hose did not appear to be leaking, but it certainly was no longer "flexible". I had purchased a new one before I started, and ended up destroying the old one anyway to get it off; so no longer have a choice about replacing.
I will try slip joint pliers. Thank you for the pointer.
Old 10-12-15, 11:32 AM
  #119
jim662
jim662's Avatar
I did this repair over the weekend and have the following 2 cents to add.
In order to remove the throttle body to bracket bolt, remove the heater hose closest to the passenger side. That gave me plenty of access to get a gear wrench on the bolt. I think it was 10mm. I tried for a long time and there was no way I could get it without removing the hose.
The 14mm bolt on the plenum to bracket is a beatch. I wound up using a 1/4" socket and ratchet. It took a good long while to get it though. Also, I had to push one of the hard lines mounted to the firewall over 1/4" in order to have room for the head of the ratchet in that little space. Getting purchase on the bolt was being blocked by this line as it was stopping the ratchet and socket from fully engaging the bolt head.
If you're doing this job, buy the wire harness even if you think you are good removing wire connectors. Both of mine just snapped when I put any pressure on them.
The upper radiator hose manifold needs to come off. I didn't realize it at first. This means removing the two long bolts that go through the engine dog bone stay.
I did not have to disconnect the fuel line. Once I freed the lower intake manifold, I just lifted it out of the way with the fuel line connected.
And parts.... I used Toyota/Denso sensors bought through ebay. The name "Denso" was stamped in the plastic near the connector and they came in Toyota packaging. They were about $60 each. There was another seller selling "Denso/Toyota" sensors that were not stamped "Denso," though they were in Toyota packaging as well. I was so sure they were Chinese knock offs that I spent the extra money. Now, I don't know if they were legit or not, but neither of the two sensors I took off had "Denso" stamped on them. And, around the bolt head of the sensor, they were etched with the same "M" in a box that is seen on the $10 Chinese sensors. So, I have no idea what is a true OEM sensor and what is not. According to Denso though, if they make them, their name is on it. So I don't know if Toyota had a different OEM supplier in 2001 or if the sensors had been changed in the first 100K miles of life.
The whole job took me more than 8 hours leisurely. That included a good long time looking for dropped bolts.
Old 10-15-15, 08:12 PM
  #120
Pzindy
Pzindy's Avatar
Thanks to all the previous posters above I got this done. I have done oil changes and changed one air/fuel sensor, but not much else DIY on the RX300 until now. This project was daunting, but if someone with my little experience can get it done, then anyone can.
I carefullyy labeled everything with orange dust tape and a sharpie. It was 2 weeks from the time I bought the parts until I had everything back together. I do have the luxury of an extra vehicle, which made this less stressful.
I think the biggest challenge was the hidden bolt on the throttle body. I got it off easily enough, but could not get it back on. I seem to have lost it.
The first time I put it all together I had some coolant leaks. Re-did some clamps, to throttle body, and upper radiator hose.
For the bypass hose, I gave up on the spring clamps, did not want to use plain worm drive clamps after researching them. Finally decided on two constant-torque clamps from NAPA. I Also tightened the front engine block drain.
Drove it about 30 minutes tonight. It shifts into O/D, no CEL, no overheating, and no apparent leaks!
It took me a lot longer than going to a shop, but I got it fixed and learned a lot about the RX300's systems on this project. Not really sure how much labor charges I saved. I bought sensors, wire harness, PCV valve, and radiator hose from Lexus dealer. Gaskets from Autozone.
Again, thanks to all the people who posted great help in this thread!
99RX300PDX (12-04-19)
Quick Reply: RX300 knock sensor replacement DIY
