how do you guys remove these bolt?
Old 02-27-10, 10:02 PM
silvertn35
silvertn35's Avatar
Default how do you guys remove these bolt?
Ok so I want to take my valve cover off and check for sludge/ check the overall condition before I do an oil change on the RX. But these bolts are kicking my butt, what do you guys use to remove them? I've already broken the tips off 2 of them.
Sorry to whomever I stole these pics from( If it offends you or if there is a problem please tell me and I will take my own tomorrow):
Old 02-27-10, 10:20 PM
Nad1370
Nad1370's Avatar
You don't need to take those off to remove the valve cover.
Those are studs for the engine cover.
Old 02-27-10, 10:27 PM
silvertn35
silvertn35's Avatar
seriously? because I removed all of the 10mm bolts and it would not budge. there are also 2 holding an electrical harness on the back side looks like its for the fuel injectors. Maybe I'm just ignorant but I had all of them removed and the valve cover would not budge.
Damn if that's the case i feel stupid. I mean I didnt put too much effort into it but it was rather frustrating.
Old 02-27-10, 10:37 PM
salimshah
salimshah's Avatar
You need torx "female" socket.
I have not removed the valve head, so I cant say if they need to be removed, but the right tool is the torx socket. HarborFreight sells a set for less than $10. I know they are not the finest tools but for occasional use they are OK.
Salim
Old 02-27-10, 11:13 PM
Nad1370
Nad1370's Avatar
The ones in the front you don't have to take out.
The other 2 torx studs that salim is talking about holds the harness in place.
This was a Biatch to get out even if you have the tool.
In my case it was so rusted that it rounded off.
Before I bought my RX, I also had to make sure there was no sludge present.
So here's what I did. Forgive me please......Been like this for 2 years no issues.
Just get a sturdy flat blade screwdriver and get in between the valve cover and the cylinder head and pry it up.
Attached Thumbnails how do you guys remove these bolt?-imgp5325.jpg   how do you guys remove these bolt?-imgp5326.jpg
Old 02-27-10, 11:21 PM
Nad1370
Nad1370's Avatar
Oh yeah... there's a 10mm bolt hidden under the harness and coolant hose.
Total of 9 10mm bolts.
Old 02-27-10, 11:29 PM
salimshah
salimshah's Avatar
I would not worry too much about where the pictures come from as long as a wrongful claim is not made. Picture is worth thousand words. Lexmex has posted a lot of pictures and his TRD oil cap is a dead giveaway. The other give away is the (ahem) pristine condition of the engine . One can practically eat off my engine bay. But that is a different story!
Salim
Old 02-28-10, 06:28 AM
JohnLX300
JohnLX300's Avatar
I bought a craftsman external torx set, for this. I couldn't just buy the one I needed but the whole set. I think I paid around $30.
Old 02-28-10, 07:53 AM
silvertn35
silvertn35's Avatar
So then they are not necessary to remove the valve cover? Except the 2 in the back holding on the harness ?
Old 02-28-10, 09:36 AM
Nad1370
Nad1370's Avatar
No.
Just to 2 in the back because it holds the harness and covering 1 bolt.
Old 05-15-16, 12:33 AM
hsmac
hsmac's Avatar
Salim
can these be replaced with normal bolts? having a hard time finding these sockets.
Old 05-15-16, 05:16 AM
2KHarrier
2KHarrier's Avatar
As long as the thread size and shank match up to the original fastener, yes, I would think you could replace them. It's easier to install the engine cover with those stud style fasteners, but there are options out there..
Old 05-15-16, 08:45 AM
salimshah
salimshah's Avatar
For light duty and seldom used tools, visit your HarborFreight store.
I have invested in a socket set for torx, inverse torx and allen key. They also help me torque to spec.
Salim
Old 05-15-16, 09:07 AM
fastnoypi
fastnoypi's Avatar
If you are not close to a harbor freight or hardware store to get external torx sockets, use the double nut method to extract the stud.
Old 05-15-16, 09:47 AM
Derrick71
Derrick71's Avatar
I stumbled across this set at the Flea Market but it's the same brand a lot of auto parts stores sell. AmPro made in Taiwan. A local auto parts store should have these if you're not close to a Harbor Freight. They'll be a little more than Harbor Freight but less than other tool sellers. I've found them to be a good balance between cheap/soft Chinese tools and pricey USA made tools I buy for my more used tools.
They're generally referred to as E-Torx and are sized as E6, E16 etc...
Quick Reply: how do you guys remove these bolt?
