New lights
Old 02-26-10, 02:02 PM
jayrocem
jayrocem's Avatar
Default New lights
Can i retrofit 01 headlights into my 99 rx
Old 02-26-10, 03:17 PM
Nad1370
Nad1370's Avatar
If it's 01 non-hid to your 99. Then yes it will work.
If it's a 01 w/ HID...then I don't think it will.
Connectors for the HID lights are different. but everything else is the same.
The 01 HID will also have a computer for the lamp and a motor leveling sensor.
I'm sure its doable but with a lot of modification, time and money involve.
It'd be cheaper if you just get an aftrmrkt HID kit.
Old 02-26-10, 06:19 PM
BurnishedGoldRX
BurnishedGoldRX's Avatar
Pretty much what Nad1370 said. I did a retrofit of the HID headlights into my 99. I ended up running wiring from the battery for them. You can do a direct wire / wire connector solution, but I used a relay to protect my HIDs. I didn't hook up the leveling motors but considering that most Acuras didn't have auto-leveling on theirs, I don't consider it a big concern. I've never had a problem with them.
Old 02-26-10, 08:42 PM
silvertn35
silvertn35's Avatar
you would be better off buying an aftermarket HID kit. It will include ballasts and bulbs and they are plug in play. You need a 9006 for low beams.
Old 02-27-10, 04:13 AM
JohnLX300
JohnLX300's Avatar
Could you use the HID kit for the High Beams, or would you have the disable DRL for that?
Old 02-28-10, 07:55 PM
ivan1
ivan1's Avatar
you would not be able to use HIDs for highbeams because you have to warm up HIDs, you can't just flash them on. unless you keep them on for a while. and yes you would need o disable the DRLs
Schiag
11-08-18 08:31 PM
Nguyen07
10-12-14 08:28 AM
j_version_
02-22-08 06:56 PM
Devir
Lighting
09-10-07 09:15 AM
Ckaler
08-14-07 03:44 AM
Quick Reply: New lights
