DIY: Replacing air/fuel sensor
Old 06-26-10, 02:09 PM
  #61
Lexmex
Super Moderator
Lexmex's Avatar
Absolutely nasty on the front sensor.
Attached Thumbnails DIY: Replacing air/fuel sensor-img_2283.jpg   DIY: Replacing air/fuel sensor-img_2284.jpg   DIY: Replacing air/fuel sensor-img_2285.jpg   DIY: Replacing air/fuel sensor-img_2286.jpg
Old 06-26-10, 06:55 PM
  #62
Benjamin T
Benjamin T's Avatar
I just got a P1130. I could only get the Bosch version because a Denso was not available on such short notice. Someone mentioned above that Bosch is no good... why?
Also, If one sensor goes bad, does that mean the others are soon to follow? Should I replace them all together?
Old 06-27-10, 09:36 PM
  #63
Lexmex
Super Moderator
Lexmex's Avatar
I've remembered hearing from some members they sometimes had issue with non-Densos sensors. You can give it a shot and see what your experience is, but given you needed it quick I can understand.
In my case above, I always knew in my case when I was going to replace one I was going to replace the other at the same time. Sometime the sync won't be there with air/fuel given how badly deteriorated one sensor is versus another. The CEL light might not come on but you might notice perhaps an odd driveability (not necessarily a hesitation, but a stagnation with one bad sensor and one new sensor).
My sensors were still running, but given their condition, I knew my MPG could be better now back on U.S. gasoline unlike the Mexican junk.
Old 06-28-10, 06:46 AM
  #64
Benjamin T
Benjamin T's Avatar
Thanks Lexmex.
Old 07-14-10, 04:10 AM
  #65
Hatchman
Hatchman's Avatar
Thank you all for the info on this thread! I got the Denso sensor from Amazon and the oxygen sensor socket kit and with the help of a little PB Blaster, I got the rear (bank 1 sensor 1) sensor replaced yesterday. Cleared the code pulling the 20amp EFI fuse and now crossing my fingers to see if my P1135 code comes back.
Thanks again for all of your inputs!
Old 07-20-10, 11:49 AM
  #66
shikbas
shikbas's Avatar
Thank you all for this nice write up,i have a question,will you able to tell me which and where is every one of these sensors is thank you
Old 07-20-10, 01:48 PM
  #67
bearbrew
bearbrew's Avatar
Default A/F Sensors
Bank 1 Sensor 1 is the sensor located in the rear exhaust manifold, firewall side, and is accessible from underneath the auto on the passenger side.
Bank 2 Sensor 1 is the sensor located in the front exhaust manifold, aft of the radiator, and is accessible from the top side.
Pictures of both sensors with removal/installation instructions are written up elsewhere on the forum.
Bear
Old 07-20-10, 03:24 PM
  #68
shikbas
shikbas's Avatar
thank you,what about the other 2 b1s2 and b2s2
Old 07-20-10, 05:34 PM
  #69
dejafa
dejafa's Avatar
i was just wondering than, is it the same denso part# 234-9009 for both the bank 1 sensor 1 and bank 2 sensor 1 a/f sensors?
Old 07-20-10, 05:42 PM
  #70
Lexmex
Super Moderator
Lexmex's Avatar
yes, it is the same sensor for both those banks you mentioned.
Old 07-20-10, 05:44 PM
  #71
dejafa
dejafa's Avatar
Thanks for the quick reply Lexmex! Is it the same for the 3rd a/f sensor after the catalytic converter as well?
Old 07-20-10, 06:54 PM
  #72
bearbrew
bearbrew's Avatar
Default Sensors
No, the sensor aft of the cat is an O2 sensor not an A/F sensor and has a different number.
You can do a search for the O2 sensor on the forum.
Bear
Old 07-28-10, 06:57 PM
  #73
john0123
john0123's Avatar
I had P0135 error. Got a Desno at Advanced Auto Parts and changed it out using this DIY. Thank you all for the info.
Old 07-29-10, 07:43 AM
  #74
shikbas
shikbas's Avatar
Hello John,did you have any trouble getting the sensor off the mani thank you
Old 07-29-10, 07:48 AM
  #75
john0123
john0123's Avatar
Yeah i did because at first i didnt use a breaker bar. But i bought a breaker bar and it came off. I also had probelms pushing the tab and pulling out the plug. Had to get my bro to push on the tab from the hood while i pulled on the plug from the bottom.
Quick Reply: DIY: Replacing air/fuel sensor
