Overheating
Old 02-17-18, 02:24 PM
Threeinone
Threeinone's Avatar
Default Overheating
My 2001 is overheating at idle. It starts when I turn off the a/c or start driving again. Any ideas guys?
Old 02-17-18, 02:29 PM
Kodiak303
Kodiak303's Avatar
You may have a leak. You can use uv dye use uv light will yellow glasses. This will help spot the leak. They sell kits for a/c or water system leaks.
Old 02-17-18, 02:30 PM
Kodiak303
Kodiak303's Avatar
or better yeat make sure, your fan kicks on without a/c. Could be a relay that’s out. Be sure to check all fuses
Old 02-17-18, 02:34 PM
Threeinone
Threeinone's Avatar
I meant to say it "stops overheating" when I turn off the AC or start driving. Could that still be a leak? Radiator and reservoir are full.
Old 02-17-18, 03:55 PM
Kodiak303
Kodiak303's Avatar
no, it’s not a leak issue. The problem is do to the fan not kicking on when the car is sitting. Once it reaches operating temp. It should kit on. Check your fan fuse, or your fan relay. If there is no fan on while sitting it will overheat
Old 02-17-18, 04:21 PM
Kodiak303
Kodiak303's Avatar
By the way, how do you post a new thread..? I’m new to this..,lol would really appreciate it
... I have sent a private mail with instructions.,,,, Salim
Old 02-17-18, 09:18 PM
salimshah
salimshah's Avatar
It seems a problem of air flow. Start by visually examining for air blockage. You can use compressed air over the radiator or water. [Do not use high pressure washer as it will bend the fins].
Then check the connector at the bottom of the radiator. Get the circuit diagram and confirm that you can short the terminals of the connector to see if the fan kicks in. [There is a thermal switch at the bottom of the radiator. I would like you to make sure it is safe ... both keep your hand/fingers out of the way, and electrically safe to jump the terminals].
Salim
Old 02-24-18, 06:39 AM
Threeinone
Threeinone's Avatar
So I'm narrowing it down and I went to AutoZone for a temp switch. The one they gave me is not like the one I pulled out. The one they gave is thin and has smaller thread. The tech manual I found online calls it water temp switch no. 1. The dealership says it's no. 2. It's at the bottom of the radiator on the passenger side. Lexus wants $120. Any ideas on a cheaper option?
Old 02-24-18, 06:41 AM
Threeinone
Threeinone's Avatar
And a part no. please!
Old 02-24-18, 07:37 AM
salimshah
salimshah's Avatar
Please check the online parts site ... such as Lexus of south atlanta. There is temperature sensor near the top of the engine and a switch at the bottom of the radiator.
Before you buy the part, follow instruction on how to test it. You can always throw a part.
Salim
99LSprobs
09-06-18 04:55 AM
magneti
Performance & Maintenance
35
08-01-16 10:47 PM
Lhh305
10-22-15 06:13 PM
kmy
10-31-12 04:54 PM
03is300ztk
IS - 1st Gen (2001-2005)
22
08-12-11 07:36 AM
Quick Reply: Overheating
