switching to synthetic ATF
New transmission was put in my 99 RX300 about 15k miles ago. There are 132k miles on the car total. I am thinking of switching to Amsoil synthetic ATF. I am going to drain the old oil and refil with synthetic. But since draining the ATF through drain plug only partially empties it, can both synthetic and old non synthetic oil co-exist? Can it cause problems?
An other question on different topic. I noticed when I unlock the doors using the remote key, the car beeps but lights don't flash. When I lock the doors, the car neither beeps nor the lights flash but I can hear the locks click to lock. Any way I can change the behavior? I would like the lights to flash. Thanks.
1 Post
not sure about the mixing of the the ATF fluids but you could do this:
https://www.clublexus.com/forums/rx-...er-change.html
I have done it myself and its not bad at all, it allows you to change 7 out of the 9 quarts of atf
Super Moderator
I have 140K miles on my RX300 and also changed out to Amsoil ATF within the last 10K. I did 3 drain and fills over the course of about 3 weeks, though I did it after about 100 miles of driving each time (to simulate a commute). There was no problem at all doing this, and in fact I could feel the Amsoil ATF after the first drain and fill with some way smoother shifts.
Don't forget there are two drain plugs, the front differential on the left and the tranny pan on the right, though filling up is only done through the tranny dipstick.
Super Moderator
Amsoil Synthetic Universal ATF
http://www.amsoil.com/storefront/atf.aspx
Note on service life:
SERVICE LIFE
Recommended for 50,000 miles in severe service* and 100,000 miles in normal service;* or per vehicle manufacturer-recommended intervals, whichever is longer.
*As defined by vehicle or transmission manufacturer
SERVICE LIFE
Super Moderator
BTW For those newer RX-series (not the RX300) that run the Toyota WS (World Standard) ATF, there is an Amsoil ATF for that,
http://www.amsoil.com/storefront/atl.aspx
I should also note that at least in Florida if you are near a Murray's Speed & Custom, that is where I have seen Amsoil products (they also sell Redline oil products, too), http://www.murrayauto.com
I also saw it when I was in Bradenton, Florida at Carquest, http://www.carquest.com/
Excellent...
Good question. There is more than one, but the Amsoil in question for our vehicles that run Type IV is this one,
TunedRX300 has gone over 50K on this, I am probably still around 10K or so since I only got it when I got back to the U.S.
I went on their site, and the one they show online has a silver non-translucent bottle, but your picture looks to be a white semi-trans. bottle. Ugh...
Since I'm "high" in mileage, I'll continue to work it out at 50K or so.
Super Moderator
I saw the plastic ones when I recently went by Murray's and they also had the big gallon jugs, too, either way, it's the same stuff.
