Timing belt should I or shouldn't I
Girl friend has a 2000 RX300 showing 102K. At 56K, the local Lexus dlr replaced the engine except for heads under warranty due to the sludge build-up issues they had.
Now, a local and very good but VERY expensive shop wants $1500.00 to do timing belt and water pump. Belt was replaced at 56K. My question, I'm a dang good back yard mechanic though I don't have an OBD tool. I've done belts, pumps and tensioners on my Volvo turbos. Is this something I can do with out special tools to lock the cam gears and crank?
Any good but not so expensive recommendations for shops in the suburbs of Detroit.
Lexus here in Charlotte quoted me around $750 for both when changed out at the same time. Around 500 for the belt replacement and 250 for the pump. $750 total, parts + labor.
It sounds to me like you're saying that the timing belt has 54,000 miles on it. And, the recommended interval for changing it is 90,000 miles. If I'm understanding what you wrote, I'd say wait for the 90,000 mile point.
What what what ????
Unless it's a speciality shop like radio or suspensions... no independent shop should charge more for maintenance than the dealerships. If you've got $1500 to throw in this economy on maintenance, then bring to Lexus and get the full 60K maintenance done, should only be about $1500 before taxes, and it includes the timing belt, brake bleed, all filters, etc.
It`s only got 46,000 miles on it, you have at least another 40,000 miles to go on it. I would not tackle this job,when it`s hardly got any wear on it.
Wow! Thanks you guys for the good insights. For sure I don't get quite as immediate responses from a Volvo site I'm use. We've decided to let it go at this point based on your input. Now I'm told the dash control wont take the heat to the floor and just blows through the a/c vents.
I`m not sure who originally posted this, so forgive me for that.
The noise is coming from the servo motor that moves the door for the "mode" button. This servo moves diverters to change from vent to floor, etc.
- I popped the bottom panel off under the glove box.
- I then removed the glove box assembly. 2 screws up high, 2 bolts down low.
- With the key on engine off you can press the mode button and watch the servo move. Turn the key completely off.
- Remove 3 screws and plug to take the assembly out.
- Do not attempt to rotate the arm on the end of the servo. It engages w/ a worm gear. Turn it and you will break gears.
- The servo is a snap together unit. Carefully take it apart w/ the arm side down.(so gears don't fall out)
- inside you will see multiple wiper fingers that make contact w/ a gear. Carefully clean these w/ alcohol and a cotton swab.
- Redistribute the contact grease on the wiper pad w/ a clean finger (any oil or lotions on skin will mix w/ the grease and make the copper contacts corrode.
- Carefully snap unit back together.
- Clean contacts on the outer part of servo also w/ alcohol.
The other option is to have Lexus diagnose this for you and hit you for $160 for the part plus ~ an hour or 2 labor.
So far the noise is gone and the HVAC system works properly. I will post any updates if the problem comes back. I think the problem was caused by crusty contacts in the servo that were creating a poor signal back to the computer that controls it. Now that it has a clean signal, all is well.....
Timing belt is surely a DIY thing - very easy.
Took me 3 hours 15 minutes to replace the timing belt and water pump on 2002 RX300 AWD. Most difficult part was removing the crankshaft pulley; was accomplished with a $15 steering wheel puller purchased at Harbor Freight Tools. Truth be told; the belt, idlers, and pump were in excellent condition and most likely didn't need replacement.
Oh yes; I'm a software engineer, not a mechanic. If you are a mechanic, you should be able to do the work in 1/2 the time.
Super Moderator
How many miles did you have on your RX when you did this?
mljohnson2
GX - 1st Gen (2004-2009)
01-18-17 09:56 AM
