I adapted a socket to fit front diff drain plug.
I started a thread a few weeks ago due to my inability to get a wrench or socket on the 24mm front differential drain plug. The short plug hex head is partially recessed, and a structural brace blocks access by a socket. I looked and looked, and finally bought a Snap-On u-joint type socket which I cut as short as possible. I then removed the u-joint part, and I could turn the socket with a Torx wrench inserted through the hole at the top of the socket. The dealer had told me (correctly) that the drain plugs aren't in that tightly -- they're just a bear to get at.
What a goofy way to design service accessibility!!
Anyway, it works, and it's the only thing I've found I could use. Maybe some of you have done the same thing. I figure I'll save in dealer labor more than what I spent on the socket.
Super Moderator
Ah yeah, I see how you did this. That is very neat. There is a 10 mm wrench I attach a drill a hex-bit to in order to get off the tranny drain and front differential bolt, will show it the next time I do a drain and fill.
I just did this project today, the fill plug took more effort than the drain plug. I used a Snap-On 24mm wrench, the box end worked well I just needed to muscle it out and it loosened just like that.
Yeah, I was surprised it fit, the walls are really thin and the 12-point box seemed to grip the plug extremely well. I guess that's what you get with Snap-On.
Pnuge88
09-16-17 06:34 AM
