I have a bad gas mileage, how about yours ??
Old 05-17-11, 04:35 PM
  #121
jbl-1985
jbl-1985's Avatar
That seems to be the norm for a combined rating. I get between 18-20 combined and 22-24 on the highway for my '99 RX.
Old 06-07-11, 12:23 AM
  #122
OzrkFisher
OzrkFisher's Avatar
At last check I was at 15.8.... not so good for a 99rX... but my 4runner got like 8. Brian
Old 06-10-11, 08:28 PM
  #123
mno221
mno221's Avatar
Originally Posted by Lexmex
Now this is the air assist hose after I have sprayed cleaner into the IACV hole at the top and you will note the cleaner coming out of the air assist hose.
Lexmex:
i follow these steps to a T, but now on a cold start it idle rough like it going to die out for about 60 sec then smooth out, did i do something wrong.
Old 06-11-11, 05:53 AM
  #124
Lexmex
Super Moderator
Lexmex's Avatar
Originally Posted by mno221
Lexmex:
How long have you been doing this? Sometimes it is still a bit clogged in there and things have to come out.
Old 06-12-11, 04:05 PM
  #125
mno221
mno221's Avatar
Its been about three weeks since i did the cleaning.
Bat.
Old 06-13-11, 04:41 AM
  #126
Lexmex
Super Moderator
Lexmex's Avatar
Bat.
I find I sometimes need to do the step again, particularly if the oil is old as the crankcase ventilation would really start to cause me issues.
Old 06-20-11, 03:24 PM
  #127
ilanh
ilanh's Avatar
Lexmex: can you explain the nature of problem and how related to he air assist hose? Thanks
Old 06-21-11, 05:03 AM
  #128
Lexmex
Super Moderator
Lexmex's Avatar
On the air assist hose you need to reclean it and the little black box (has two small hoses going into it) known as a baffle. I'd also reclean the the IACV again along with the MAF sensor. I'd also reset the battery after these steps, because the vehicle's computer is going to assume otherwise that nothing has changed.
Old 06-21-11, 08:13 AM
  #129
mno221
mno221's Avatar
Still nothing change, could it be possible that the MAF is bad. Because i have to keep my foot on the gas for about a minute then it will smooth out, and its doing it now even when its hot.
Old 06-21-11, 01:35 PM
  #130
Lexmex
Super Moderator
Lexmex's Avatar
What are the RPM numbers you are getting in Park and Drive with your foot on the brake at startup?
Old 06-22-11, 10:32 AM
  #131
mno221
mno221's Avatar
When i start up it die out, i have to keep my foot on gas to keep it running, it run rough like it gone to die, RPM 2/300 then after about a minute of rough idling it smooth off and RPM around 1000/1100.
Old 06-23-11, 05:51 AM
  #132
Lexmex
Super Moderator
Lexmex's Avatar
I'd run some fuel injector cleaner in your gasoline next tank full. The air flow would be practically immediate through the throttle body and the IACV and even its hoses, but the one constant that won't hold true is fuel delivery and I can see any clogged injector causing the issue mentioned above where it takes about a minute. The only other possibility offhand is a leak anywhere on the IACV or one of the hoses...I'd also check the rubber o-ring underneath the MAF sensor.
Old 07-06-11, 11:59 AM
  #133
mga555
mga555's Avatar
I've had the 441 code for a couple years and have been able to get it through the NY emissions inspection. The computer doesn't check the evap system if the gas tank is over 7/8 full. Here is what to do. Fill the tank then clear the code. Drive the car for about 30-40 miles and keep the gas tank full. The CEL should stay off. Driving will reset the monitors in the computer except the evap system. In NY for a 1999 car, 2 monitors can be incomplete and still pass. Hope this helps.
Old 07-16-11, 11:31 AM
  #134
DorianB
DorianB's Avatar
I wanted to ad my 2 bits about cleaning the IAC valve.
First of all, Thanks LEXMEX for your great picture DIY's. I've used a couple of them and found them VERY helpful. Especially the door panel removal and aftermarket actuator installation.
With regards to the screw removal on the IAC valve motor...... On my 2000 RX300, the screw heads were already buggered up a bit. No screw driver would seat in it well even tapping it with a hammer. I was fretting over using my electric 1/4 inch impact, but seated with a new bit, it broke them free easily and immediately.
So for those wondering if it is a good idea or bad...... My experience was good. I probably wouldn't have gotten it off any other way.
Thanks again!
Dorian
Old 07-22-11, 05:43 PM
  #135
rxgxmdx
rxgxmdx's Avatar
The combined mpg for my 99' RX is around 20-21. The funny thing is I think its fuel economy actually improved a little as the car aged (I bought it new).
Quick Reply: I have a bad gas mileage, how about yours ??
