Spark Plugs DIY (if you have the patience)
#151
Its been a while ,,, going by memory you have to unbolt the coil-pack from the top of the plug . If you want to change/swap than you unclip it the coilpack from the harness. Its not a biggie to unclip the coilpack.
Just be careful in removing the plug down hole connector. I went around the seal/boot to break the bond and then pulled on it. If you try simply yank it would not budge and do not, do not use a pliers to hold and pull.
Salim
Salim
#153
Smooth Replacement Thx!
Got it done in about an hr. Just be patient and body part flexible! Great tutorial and words of encouragement in this thread. Toughest part was getting those connector clips to release. Used different sized screwdrivers to gently help lift the tabs some and pry and twist the blade to help push the connectors off. Just pushing the tabs down with fingers wasn't cutting it and is painful.
My 'special' tools that really made the job easy were a ratchet box wrench for the coil bolts, a short extension pipe on my ratchet handle for more leverage to get the driver side plug removal started, multiple short extension bars to address clearance for plug access, stubby adjustable head ratchets, and a piece of fuel line to push over the head of the spark plug for removal and installation. Lastly, get both hands in there working. One on each side, obviously. Power restored and mileage is way up. They didn't look that bad but 158K and don't know if previous owner had replaced them. Used the Denso Iridium and Denso coils.
#154
Thank you for this info!!!
Lexmex you saved me over $400.00 with this info. I don't drink but if I did I would be celebrating right now. Thank You Thank You Thank You!!!
#155
Thanks to the OP and others for the instructions and the encouragement. I was able to do it rather quickly on the ES300, only had to remove the PCV valve and was able to get the torque wrench on all but the rear center plug. Interestingly, the original plugs looked great after 120K, the gap was spot on.
#156
since it seems like i won't be able to torque parts down, about how much of a turn/how many turns is 13 ft/lb and 69 in/lb after finger tightening?
also does this take roughly an hour? i think someone said it took him 4 but also mentioned some sort of disability.
#157
For me with the small ratchet I fold my fingers in U shape and bring the ratchet on to my fingers 1/3 near the base of the palm. Then apply a gentle continues force and as soon as I feel the ratchet bite into my flesh I stop.
Train yourself by playing with exposed 3 plugs.
Salim
#158
changed rear plugs today. gearwrench swivel spark plug tool is amazing. i originally had a tough time removing connector from right coil, but reached around the intake from the left side with pliers and it came right off. it's easier to do this job blindly (you sort of have no choice regardless) and attempting to get light on what I was working on was more difficult than the job itself.
#159
one of my plugs came out a little dirty. maybe even a little oily, but i stuck my finger and some paper towel around the top of the cylinder and they came out clean, leading me to assume oil was no leaking from the gasket. the other two were clean. how does it even get dirty and do i need to be concerned or address anything?
#160
Next time dont use anything other than vacuum down the the hole. Dirt grime etc can get in the cylinder.
Salim
#161
i should have been more specific. electrode side. the opposite tip side was clean.
#163
#164
Plenum?
Question about the plenum. If I remove the wiper cowl would it be possible to just loosen the plenum and throttle body to maybe raise it 1/4 to 1/2 inch? My hands are getting chewed up trying to do this.
Thanks,
Sean
Thanks,
Sean
