Advice to increase MPG
2000 RX300 AWD.
I have been trying almost anything to get my MPG up:
Mobil 1 5W-30 since new
K&N Drop In filter
New Iridium NGK plugs
1 can of BG-44k in the tank
New Cross Terrains in stock size, inflated with Nitrogen
New PCV valve.
Car empty of all junk (except spare tire)
Yet I constantly get 16 MPG.
I am going bonkers trying to get my MPG up closer to 20.
Is there ANYTHING else I can do to get closer to the EPA ratings, does anyone here actually get 20MPG on their AWD RX?
K&N Drop In filter
New PCV valve.
Originally Posted by toy4two
2000 RX300 AWD.
K&N Drop In filter
New PCV valve.
K&N Drop In filter
New PCV valve.
See your problem is being AWD.. That kills your MPG...
I dont know what else you could do... a lot of times people who put intakes and exhausts on their cars report a few better MPG....
What a lot of Landcruiser (4WD) guys do is drop the front drive shaft and lock the center differential on their trucks and just drive around with the read drive shaft in place (2WD)
that saves gas... but the RX doesn’t have a center differential lock so you couldn’t do that...
Hope that helps
-Tommy
Recommendations....
Tires - The Cross Terrains have higher rolling resistance than the OEM Goodyears. Since you have new Cross Terrains (great tires by the way), it would be silly to change the tires just to get a little better mpg. That being said, check that your tires are properly inflated, if not slightly overinflated would give you better gas mileage.
Alignment - car tracking straight?
What mix of city/highway do you do?
My 2000 RX300 gets 22mpg with 90% highway driving gingerly - lead foot will definitely kill the gas mileage.
I'd like to ask whether you use the MPG from the car's display or calulate it manually from the odometer and gas pump results. My MPG display results are higher than most others, and I suspect my car's MPG display reads higher than actual (although I haven't bothered to check).
What type of terrain?
What sort of trafic you encounter?
Have you checked long distance mpg (cruise set).
All windows up and AC at reasonable setting.
Salim
Salim
Can this be your particular driving style or type of driving you do (city v. highway)?
We have a 1999 AWD and around town it is 18-20 MPG and on trips it is about 24 MPG. This of course is with a woman driving and we have never seen below 17 MPG. If I drive the mileage is lower because I tend to drive harder.
Car is 100% stock with Michelin tires.
H
H
2000 RX300 AWD.
K&N Drop In filter
New PCV valve.
K&N Drop In filter
New PCV valve.
Originally Posted by Lexmex
You know what my little RX has been getting recently with all the mods...12-14 MPG, but of course I am at higher altitude being the major killer.
Improve aero-dynamic will help highway mpg and reduce wind noise. If you don't use your roof rack, take them off. Considering Lexus sedans never have mud-flaps, you can also take them off.
When it is time to change tires, consider a lighter weight tire. Tires are mounted more than 16" of mount arm from the center of drive axel. TireRack is selling Goodyear Eagle ResponsEdge 235/60/18 that is 23lb per, 7 lbs less than 225/70/16 Michelin CrossTerrain. That is close to 21 lbs-ft for FWD and 42lb-fts when AWD is engaged that one can save during acceleration and braking.
Better Gas Mileage
I too have a 99 RX300 and consistently get 16 around the city and just recently I drove my 88 Mercedes 300CE and got 21 for the same driving. I never use the mpg off the display its always been reset the odometer and do the math. So the AWD must be the problem.
Super Moderator
I remember you had some lightweight rims that must also help. I was looking at some Rota aluminum rims recently in the 16 inch range that were under 14 lbs. a rim.
