Oil filter wrench?
Old 04-28-06, 05:17 PM
81corolla
81corolla's Avatar
Default Oil filter wrench?
I am trying to find a good universal oil filter wrench for my RX300 and it's proving to be difficult.
This is my first oil change on my 2000 rx300 and I want the right tool for the job.
I found the typical #4 end wrench that fits over the top of the filter. It's fine for Mobil 1, Bosch or any filter with 16 "hex" edges (hex is a misnomer, I know.) Yet some filters don't have the "hex" edges so a loop wrench will do better with those.
Granted, I hope to do all future oil changes myself (this will be my first) yet if some shop does use a filter w/o the hex edges I don't want to have to run out for another wrench. Hence the "universal" adjective in my search.
I did find a wrench that loops around the filter and has the 3/8" socket in the end. Perfect, except it only loosens - arg! On my old car I just hand tightened the new filter. But because this filter is such a PIA to reach, I'm not sure how much grip I'll get on it and want to be able to cinch it up a *little* with the wrench.
I could buy both wrenches ($5 & $6) but do I really need to/two?
If you can post ideas on where to shop or what wrench will do the job I'd appreciate it.
Thanks,
Sam
Old 04-28-06, 08:03 PM
salimshah
salimshah's Avatar
IMHO the filter should not need a wrench to tighten and it should come off without a wrench. But I do have to reach for one to undo it. I have a metal band that goes around the filter and use couple of wraps of mesh sand-paper used for smoothening out sheet-rock. To tighten face the filter and then 3/4 turn. If you think it needs more, then study the O ring on the oem filter ... it is very thin and needs very little squeeze.
Tip: drain the oil when engine is warm. Let the exhaust cool down before attempting to reach the filter.
Salim
Old 05-01-06, 09:38 AM
shawnst
shawnst's Avatar
Agreed. I never use filter wrench when I change oil for my RX300. Actually I was trying to buy one and couldn't find the right size. So I just tried using my bare hands. As long as you have good grip on the filter, you should be able to loosen it (if it's installed correctly) and tighten it.
kimsey
12-01-15 03:00 PM
wvuguy
09-15-09 09:11 AM
jagtoes
ES - 5th Gen (2007-2012)
05-01-09 08:57 PM
moya
29
06-09-06 11:48 AM
leong1
11-30-02 09:10 AM
Quick Reply: Oil filter wrench?
