Timing belt RX300
Timing belt RX300
Has anyone every changed the timing belt on a 2000 RX300? I know it's recommended at 90000 miles...mine is at 85k. So looking for information on how to change it myself. What is the difficulty level? Appreciate any input...thanks.
welcome to CL
you posted int he wrong forum
heres where you want to go
https://www.clublexus.com/forums/rx-models-9/
oops
Thanks for the top. I am new to this computer forum chatting stuff. How do I move a "new thread" to the proper area (like you were able to do) b/c I just posted another question and it ended up in a catergory by itself again? Im trying to put it in the RX300 forum area? Thanks again, Lexy696
The last time I changed the timing belt was on an Accord. By the time I finished, I swore, I will not replace a timing belt on a transverse mounted engine. RX is a v6 on top. The cost saving of $400 or so looks very tempting but keep in mind the factory spray finished engine bolts require more torque to open. My hands are too big to squeeze into the tiny areas and still hold on the socket-drive. Changing the darn oil filter in RX is my limit.
My advice, for the first timing belt change, take it to a mechanic. I dont want to discourage you tottaly, but do not embark on the replacement by just reading how-to. Establish the most difficult step and visualize and test if you will be able to do it.
Salim
[DIY word of wisdom: check you can open the filler, before you open the drain plug ]
Salim
Thanks for the tip. I've heard that the timing belt is the last thing I should have to worry about? That they last longer than 90,000 miles, what is your opinion? Thanks.
Salim
Salim
I had mine replaced at 90K and would reccomend to do the same to others.
Salim
Salim
Salim
Salim
What else is worth replacing when it's apart like that?
Originally Posted by OKmechanic
Not to get too off topic Salim, but did you get your water pump replaced also at 90K?
Salim
Lexus Connoisseur
70-90k is a good point to replace your timing belt. Replacing the water pump at 90k isn't necessary unless you neglected to have your radiator flush done on a regular interval.
Originally Posted by redtoesblue
I don't think you have to worry too much about the Timing belt. I haven't done mine, and the mileage on mine is 160,000 no problems as of yet.
Other things that the rest of us need to keep in mind are:
1. How extensive is the damage caused by a broken timing belt?
2. How inconvinient is to have a belt break on you at an unoppertune time & location?
Salim
Lexus Connoisseur
My service advisors says..
I actually discussed the timing belt with my Lexus service advisort this morning. He told me that the RX timing belt should be replace no later than 120k miles. He recommened the change at 100k.
I'm not sure how difficult it is on these cars, but I'd guess it's not a fun painless experience. There is limited room in the RX engine bay. If you've got the right tools and a shop manual, go for it!
Cheers.
Cheers.
