Road Course and Auto-X Discussion about road course, time trial and autocross racing.
Track Wheels and Tyres
Old 04-23-11, 02:19 AM
Blacky
Blacky's Avatar
Default Track Wheels and Tyres
Been looking at a track set up and thinking about 18" rims and tyres.
Now I have seen a few 18" running on ISF's I am a little more comfortable on running this type of set up and clearing the front calipers.
Got my eye on the following
OZ Ultraleggera's
Front 18" x 8" ET48 running 235 x 40 DOT Tyres
Rear 18" x 9" ET 55 running 265 x 40 DOT Tyres
Any thoughts or comments on this possible fit and trouble i.e. rubbing etc?
Cheers
Old 04-23-11, 06:33 AM
ming15237
ming15237's Avatar
OZ Ultraleggera's
Cheers
If this is going to be "just" a track setup, then you want to get front and rear in the same size, this will do two things, first you can rotate them front to rear, second, you will help remove a lot of the under-steer (or push) that the F is prone too on the track. p.s. unless you are from Europe we spell tyres "tires" ;-)
Hope this helps
Old 04-23-11, 09:26 AM
D2M
D2M's Avatar
^^ %100 agree ^^ 18x9.5 or 9 with 255, 265, 275.. or 19x9 all around with 255s
Old 04-23-11, 03:48 PM
Blacky
Blacky's Avatar
Thanks for the comments.
FYI I am in OZ so the spelling of tyres or tires is correct
The problem I see with running none stagger is the maximum tyre on the rear, fully agree with the comments about understeer but the reverse will be oversteer.
I am no expert but I think understeer would be a much safer situation than oversteer with an undersize rear end????
Will 255 fit all round?
Any comments on the actual fit and clearing calipers etc?
Old 04-23-11, 04:24 PM
ming15237
ming15237's Avatar
FYI I am in OZ so the spelling of tyres all tires is correct
I am not expert but I think understeer would be a much safer situation than oversteer with an undersize rear end????
What I am using for the track this year is what another member showed which is Enkei PF01's in 18x9.5 with a 45mm offset, tires are kumho v710's size 285-30-18 on all 4 corners. I have NOT found over steer to be a problem unless you are trying to steer it with the throttle (which is NEVER the fast way around a turn). Even with this setup there is still some push in the front end, the front end on our cars is VERY heavy! Hope this helps.
Old 04-24-11, 07:29 AM
D2M
D2M's Avatar
i also have a non staggered wheel/tire on mine for a while and it balances out the car nicely. excessive oversteer in not an issue at all, the car just does what you want instead of being a understeering disaster and aiming 3 feet inside of where the car is actually going to end up..
Old 04-24-11, 08:00 PM
sweetbird
sweetbird's Avatar
Tires tires tires tires tires!!!!!!!!!! Lol
Old 04-24-11, 11:06 PM
Blacky
Blacky's Avatar
285 On the front?
Very interesting set up.
Are you running anything special with front camber to get these TIRES under the guards / fenders?
Photos?????
Old 04-25-11, 05:04 AM
ming15237
ming15237's Avatar
285 On the front?
Photos?????
Nope. Look up scca forums on here, he has the exact same setup I copied, and it works VERY well! he has pics and action shots of the car.
Old 04-26-11, 01:24 AM
Blacky
Blacky's Avatar
Yep found that one on here, thanks for the heads up.
Old 05-22-11, 06:41 PM
27rocks
27rocks's Avatar
A little camber and a slight toe adjustment in the front should fix a lot of the understeer you are still having.
Old 05-22-11, 09:00 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
If only it were so easy...
Camber is not adjustable from the factory. Toe out kills the inside edges of the tires and there's lots of evidence this is true in both the IS-F and 2IS forums.
Many of us have close to -1.0 degrees camber in front from the factory at stock ride height. Adding camber would help, but so would a suspension not intentionally designed to induce understeer by every suspension component.
Old 05-23-11, 01:11 PM
hwy1isf
hwy1isf's Avatar
Can you post a link? I have not been able to locate him.
Thanks
Old 05-23-11, 03:36 PM
rhy
rhy's Avatar
^^ Right here:
https://www.clublexus.com/forums/is-...k-weekend.html
Old 05-23-11, 07:35 PM
hwy1isf
hwy1isf's Avatar
Originally Posted by rhy
Thanks rhy
cleethree
11-04-19 06:40 PM
robertrios
02-15-11 06:46 AM
phattbam
Wheels, Tires & Brakes Forum
13
05-08-10 07:46 AM
Dankysc300
10-03-08 10:34 AM
evolon5150
11-20-02 01:22 AM
Quick Reply: Track Wheels and Tyres
