Does your RCF use any oil?
Old 06-25-15, 04:29 AM
BAlbright
BAlbright's Avatar
Default Does your RCF use any oil?
I detailed my car yesterday and while I was under the hood, I thought I'd check the oil. I have 1300 miles on my car. I was surprised to see that the oil level was at the bottom mark on the dipstick. This was the first time I took a look at the oil. Perhaps the oil was never up to the top mark when I took delivery. Or is it normal for the V8 in the RCF to use a little oil? I came from ownership of a Honda Accord with a V6. I never had to look at the oil level in it. Whenever I did, it wasn't a drop down
Old 06-26-15, 03:40 PM
LexSense
LexSense's Avatar
Did you check when the car was hot or after it has rested for a good amount of time? Also was the vehicle on any significant incline?
It is possible that your vehicle came under filled from factory/dealership.
I'd say add some oil after it has fully cooled down and then check back again after awhile to see if it is indeed burning oil or leaking somewhere.
Old 06-27-15, 04:33 AM
vbx
vbx's Avatar
Wait for car to cool down before checking oil. I made a mistake of checking it after I just shut my car off once. I added a quart. checked it again and now was a quart overfilled. Didn't want to turn the car on so I stuck a small aquarium tank tube down the dipstick hole and siphoned 1 quart out. It took a long time too. I used a small syringe to slowly suck up the oil and then gravity finally did its work, but the oil still only slowly drained out.
i thought about jacking the car up and draining it from the pan but that would have been messy trying to put the bolt back in after draining 1qt.
BAlbright
RC F (2015-present)
20
03-16-19 05:11 PM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
24
05-04-17 11:39 PM
amerquresh
05-11-12 06:39 PM
swheat
06-29-09 06:52 PM
mailrail
RX - 1st Gen (1999-2003)
08-09-04 09:07 PM
Quick Reply: Does your RCF use any oil?
