RC350 FSport AWD FIGS/Swift Lowering Spring development
Hi all, just thought I would post up that we have our test car and the first spring articles in hand for installation over the next few days. Should be able to post of specs once testing is completed.
Here are the before pics as we get started on the anti 4x4 process.
Thanks, Mike
Thanks, Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Thanks, Mike
Thanks, Mike
So far the front is installed, bushings neutralized and working on the rear today.
__________________
BTW, I will be doing a full write-up with the process etc for install with more detailed pictures.
__________________
Just one pic of the car with test springs installed. Fender lip-wise the front still remains slightly higher however, chassis-wise the front sits .5" lower as measured to the frame rail from the ground.
The car drives well planted with limited sway in the corners now and a very nice damped ride that is both non-jarring and comfortable but sporty and responsive as well. We will circle back around and see if the ride heights need revision after road testing and further feedback.
Mike
Mike
__________________
Mike
Mike
From the picture it looks like the car is sagging alot in the back. There is no fender gap in back but gap in front. Is it a bad picture or is it like that? Are these springs for a GS350 that were used? I will be the official swift test car for the RWD direct from swift. Getting them installed this Saturday (6/8) so I will post up results.
From the picture it looks like the car is sagging alot in the back. There is no fender gap in back but gap in front. Is it a bad picture or is it like that? Are these springs for a GS350 that were used? I will be the official swift test car for the RWD direct from swift. Getting them installed this Saturday (6/6) so I will post up results.
Mike
__________________
Thanks for the info!
