Will 20x10 et+45 wheels fit on the rc350F ?
Got a steal on some 20x10s +45 all the way around , was wondering if any you wheel gurus out there could shed some light of they will fit. Also if I do need spacers what mm thickness will I need and does anyone know the center bore size needed? I have a mica blue awd f sport I'm also installing the tnf170 springs along with these wheels to reduce the 4x4 stance in the front. Thanks for the help in advance
Thanks for the info man! looks like I can head to the tire shop instead of trying to find adapters/spacers , going to do the spring install at the same time most likely . Once I see how flush it's sitting I might look into a wider spacer/adapter to give it a more aggressive stance
