Wrapped Door Panel, Glove Box, Center Console
And the Touch pad just unscrews from the underside once you have the console popped off.
It mainly allows you to use the functions of the system that are normally disabled when the car is moving due to "safety" reasons. This includes functions such as typing, searching for things, scrolling through certain lists, playing DVDs, etc. Links below if you want more info.
http://www.prestigioussociety.com/?page_id=138
http://www.beatsonicusa.com/nav-dvd-...us/bb6223.html
this is legit? easy to install?
I heard it's not too hard to install, but it will require taking the radio head unit off. Then unplugging some stuff and plugging them into the unit which connects to the head unit. Maybe rmsimmonsj can give us a few pointers on how to take apart the center console and head unit.
Haha thanks everyone. The carbon fiber pieces are super easy. They just pop out. The center console is a pain. Screws on the sides under the leather trim and then you have to unplug all the electronics and once out you have to unscrew everything to wrap it. 5d reflective carbon fiber is what i used and its an exact match to the rcf. Have enough for like 5 more cars if anyone in Orange County, CA is looking for this look.
I had a perfect install I took apart the whole bumper so I could wrap the lip without stretching or heat it stayed perfect till I washed the car..
FYI do not use this carbon fiber wrap on the exterior!! no mater how you wrap it with heat, no heat, with stretching, or without. The wrap will de laminate (sp) ill get a pic here soon. It seems the wrap will suck up water. as soon as i washed car it messed up the look of the carbon.
Awe bummer. Thats horrible after all that work you did. I dont plan on washing the inside of my car. Wonder why it did that. I wonder if that will happen to the other guys who wrapped their outside in CF. You took off the protective coating that comes on it after you wrapped it right? There is a clear film that is over the CF wrap so it doesnt scratch when installing....Looks like you didnt take it of from the pictures...
