Zydan RC-F Build Thread - White w/Circuit Red
#68
Thanks, I appreciate the compliments, couldn't be happier withbthis setup!
After some frustration of trying to get an alignment locally and no none having specs for our car yet I finally went to the dealership. Here's RSR springs drop before / after specs for this interested.
And a few random pictures that you may have seen if you follow me on IG: Zydan000
#69
Thanks for posting the spec. Can you tell me are the
BEFORE values what Lexus measured on your car (stock settings) and the RANGE is
what they have listed as the possible range. I assume this is a Lexus service print out.
I assume ACTUAL is after some change that you or they made. Can you give some details about the specs on this page you posted?
#72
quick question.... If i went to mavis tire and got an alignment, new tires, and balancing.... should have I gotten the sheet showing my camber, toe and stuff?
#73
Yes, they should ALWAYS give you the results back. My question is why is the alignment so out of whack for just adding lowering springs?! That shouldn't have happened in my experiences with just a spring swap. I would get an alignment, not saying that at all..... Just being out like that is kinda weird. The car and the wheels look fantastic. Nicest Vossens I've ever seen. I'm with Diesel350, it "appears" to me, and I'm not an alignment tech that it's still not aligned according to the specs. Maybe someone that knows more will chime in. Sweet wheels and build regardless!!
#74
#75
Thanks, very happy with them!
Couple more pics
