hood scoop costmetic or functional
The hood scoop is open, barely, to the engine for functional or appearance purposes? What your opinion? Hot air does come out of it a bit after i park the car, but does it do any benefit for the performance while driving is the question. Compared to the large openings for the oil and transmission cooler, the opening on the hood is dismal. Wished Lexus would made it into an actual air intake
If it's very important performance wise, why doesn't GSF have it? I know I know obvious answer is a toned down look. But the GSF has all the other vents for heat dissipation
I pulled mine out a year ago when I got my car, I get it washed weekly and tons of water pours in also it's a DD and sits in all weather and had 0 issues. Also I can see lots of heat coming out of it at red lights so I know it's working.
The stock thing sucks it has about a 1 inch hole in it and that's only to drain water out of it so I would say as stock it's looks only. Also if you drive it hard I would pull the motor cover off as well as it's a huge heat blanket.
Not to post off topic but I knew your name sounded familiar! You post quite a bit on the Club4AG forums! I miss mine but I have no regrets as I sold it for 2 first gen celicas. Anyways nice to see you are around here also!
