Anyone else rethinking their order?
Old 09-20-14, 08:48 PM
  #211
spwolf
spwolf's Avatar
Originally Posted by rominl
yup, that's why i take notes on all my concerns but i am definitely reserving my conclusions until i can drive the rcf. someone is simply lying if they think the new gs and is350 don't drive good
just last month Edmunds wrote something like "Lexus IS does not drive as sophisticated as german competition"... What? This things happen to Lexus all the time, it is auto-discounted as 2nd best.
In general, automedia is not trustworthy. I just got my best buddy to buy 520d, which is supposed to be the best diesel engine in the world, and now since A6 was facelifted, 520d has a lot of faults that it did not have last year. Somehow it is rough engine, transmission likes to hunt when cruising and real world mileage is poor. Last year it was superb, quiet, perfect transmission combo and hybrid beating mpg. You just cant trust media guys for nothing.
So I give a lot more credence to our members posting their own opinions than automedia.
Old 09-20-14, 10:12 PM
  #212
Re3iRtH
Re3iRtH's Avatar
Fair enough. However, I didn't think folks loaded 2-4 extra buddies or wife and kids and take them on a spirited cruises, commute to work, haul groceries and so forth. I asked a friend with a 2013 M3/M4 how often he has had anyone in his backseat in the year he owned it, he replied "almost never" matter of factly.
Originally Posted by Badman Forever
All my 2-door vehicles have atleast a 2+2 configuration (gt-r, fr-s, g35 coupe before as well). I prefer to maximize interior load capacity if possible and I only purchase new typically. I use to only drive rwd sports sedans (is300, is350, is-f). I'm not a fan of strictly 2-seater sport cars unless it's a LFA or other exotic.
Old 09-22-14, 06:06 AM
  #213
Furge
Furge's Avatar
Originally Posted by ISF001
I do not believe anyone is arguing the explosive power of the GTR.
With regard to the M4 and RCF discussion, you need to explore the math...
I expect to see, as a result of independent testing, the low-end acceleration of the production (non-pre-production prototype) car to be closer to the M4 and pull at least a 4.1 0-60. Why? The ISF has a power-to-weight ratio of 9.08 hp per pound versus the RCF with 8.47 hp per pound. The ISF is spec'd by Lexus at 4.6, yet it runs a 4.2 in the right driver's hands. We'll see if this extrapolation holds water in the months ahead. BTW: As a point of comparison, the M4 has a power-to-weight of 8.30 hp per pound versus the 8.47 of the RCF.
The top end is 170 for the RCF and 155 for the M4--stock for stock.
Let's get the M4 and RCF in a side by side and see how it plays out. I am expecting plenty of close shaves.
You may want to check your math, as it's completely wrong.
The M3 has a HIGHER power to weight than the RCF. That's why it's faster.
The RCF does not have 8.47 hp per pound! That would give it about 33,500 hp!
M3 auto
HP - 425
LBS - 3585
RCF
HP - 467
LBS - 3958
M3 has .1185 hp/lb
RCF has .1179 hp/lb
And you can't use this to predict 0-60 times. Torques plays a bigger role in 0-60, and the M3 has tons of torque, at very low rpm.
Old 09-22-14, 07:40 AM
  #214
obturator
obturator's Avatar
M3 auto
HP - 425
LBS - 3585
RCF
HP - 467
LBS - 3958
M3 has .1185 hp/lb
RCF has .1179 hp/lb
I think ISF001 meant lb/hp.
Old 09-22-14, 09:32 AM
  #215
ISF001
ISF001's Avatar
Correct... Forgive the unintentional confusion.
I don't believe the RCF will run a 12.2, but it will come mighty close.
The "ton" of torque you refer to is apparently not a significant advantage on tough cornering when the M4 introduces massive deceleration. Here is where the RCF TVD will shine, actually delivering torque where it matters on such corners.
Old 09-22-14, 03:09 PM
  #216
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,843 Likes on 2,331 Posts
..Torques plays a bigger role in 0-60, and the M3 has tons of torque, at very low rpm.
No it does not. Gearing makes all the difference. Engine torque by itself is meaningless. Engine torque multiplied by all the gearing in place has lots of importance.
Old 09-22-14, 04:02 PM
  #217
05RollaXRS
05RollaXRS's Avatar
Received 2,417 Likes on 1,741 Posts
Ah no. 0-60 mph is merely an indicator of traction off the line. The RS5 makes only 315 ft-lbs of torque and weighs 400 lbs more yet, it runs quicker than the M4 in a 0-60 mph (3.9 seconds) due to superior traction.
The M4 launch control has built-in mechanism that pulls back torque in the 1st gear in order to put the power down properly.
The ZR-1 with 600 ft-lbs literally most of the time it had the same 0-60 mph time of 3.8 - 4.0 seconds as the Z06 C6 with 145 HP less because the ZR-1 could not put its power down properly until it got to very high speeds.
Old 09-27-14, 04:19 PM
  #218
nonstopz30
nonstopz30's Avatar
im sticking with the ISF the 4 door that weighs less and still gets me excited when i jump in it and is paid off. i can keep 80k for something else or mod up the ISF to take out an RCF for a fraction of the cost IMO to each is own personally i think the RCF is ugly but i didnt know the numbers were mediocre i thought the was going to blast the ISF away. still want to see it in person once its gets to the dealerships. im not sold.
Old 09-27-14, 05:19 PM
  #219
ISF001
ISF001's Avatar
Nonstop,
It will out run the ISF stock for stock on the street and the track. Our rear does not perform the way the TVD does on the new RCF--just a fact.
However, who said the cars are meant to compete?
This is a new class of car for Lexus and signals the direction they are taking,
If it's not for you, that's fine. Take the $85k and trick out your ISF. My 2012 ISF is hard to give up, but it is going back to Lexus when I pick up my carbon RCF.
Old 09-28-14, 06:28 AM
  #220
begone
begone's Avatar
I applaud lexus for finally coming out with an obtainable sports coupe, but you could have at least made it perform better than the competitions outgoing models. It's slower or barely equal to the performance in the outgoing C63, outgoing RS5, and already gone e92 M3. Bmw raised the bar and we haven't even seen the others. Its like their living on an island or something.
Old 09-28-14, 06:54 AM
  #221
EndlessRed
EndlessRed's Avatar
Japan is, in fact, a collection of islands.
Old 09-28-14, 12:38 PM
  #222
begone
begone's Avatar
Ha! Thank you Captain Obvious. I've seen Godzilla... Again a joke.
Old 09-28-14, 03:16 PM
  #223
Lexura1414
Lexura1414's Avatar
I agree. Why I am cross shopping the C63, RS5 and the RC-F? Though, we do not have any REAL comparisons yet, I believe the C63 507and RS5 will out accelerate the RC-F from various speeds and it might be a toss up on the track for all 3. I think Lexus does not have the technical know how to outperform the AMG and RS without sacrificing reliability and quality.
Old 09-28-14, 04:04 PM
  #224
ISF001
ISF001's Avatar
The estimated 0-60 for the 2015 C63 is 4.3--I believe Motortrend's schnitzel eating driver also hit this speed in the desert with the RCF, and I expect it to do better.
This comparison wiill always be a matter of opinion as we are talking minute differences in performance.
I view the PROTOTYPE RCF to be the best in class in overall performance. If you want fair and actual comparison between the new RCF and the other sets of wheels, you will néed to wait until February, when the RCF with TVD appears on the seen.
I'm waiting for nothing. The RCF will easily beat the Yaguchi conservative spec on 0-60 and quarter mile with knowledgeable drivers in the right climates.
Here is another opinion:
Old 09-28-14, 04:07 PM
  #225
ISF001
ISF001's Avatar
Begone,
You are drawing conclusions based on what? Journalists driving results with detuned prototype coupes or what?
No one will know what the numbers are until the RCF carbon TVD hits the roads in February. Until then, this is all hyperbole.
As for the M4, BMW will be significantly challenged to deliver a car with the sophistication and versatility of the RCF. If I were BMW, I would be concerned. The buyer for the RCF will not seriously consider the M4 based on reliability, luxury, engine technology and sound, and overall performance.
Quick Reply: Anyone else rethinking their order?
