RC F automotive reviews thread
Old 03-26-15, 02:28 PM
  #1021
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Hey guys let's please move the Caddy talk to car chat please. This thread is about RC-F automotive reviews.
Old 03-26-15, 02:33 PM
  #1022
JDMV8
JDMV8's Avatar
RCF doesn't get my blood boiling like the ISF did. It just wasn't that big of a jump from the ISF. Equip an ISF with an OS giken, and some suspension, and I wouldn't even consider the RCF a jump at all.
There's also the counter-argument: perform mods on the RCF. And this is where I'll say back to square one: it still isn't that big of a jump.
But irrespective of the ISF, the RCF is a pretty mean machine.
Old 03-26-15, 11:24 PM
  #1023
05RollaXRS
05RollaXRS's Avatar
Received 2,417 Likes on 1,741 Posts
Drift king Tsuchiya drifting the RCF
Old 03-28-15, 11:17 AM
  #1024
aWorkOfArt
aWorkOfArt's Avatar
^ Great find! DK approves.
Old 03-29-15, 08:54 PM
  #1025
FT2011
FT2011's Avatar
Originally Posted by 4TehNguyen
BMW also has their version of a TVD also
I am not sure how this TVD quite works yet, but it appears that the electronics apply some level of retardation to the driven wheels at corner entry, either by greatly squeezing the clutch packs or applying the brakes at differing levels through the ABS system, to help the turn in.
BMW M has electronic locking differential, which is basically a 1.5-way LSD in which the lockup is determined by electronics, but there is no retardation on any wheel to my best knowledge. You may have additional information though, would you happen to have a link or name of the system?
TIA.
Old 03-29-15, 09:56 PM
  #1026
05RollaXRS
05RollaXRS's Avatar
TIA.
That is the cheap and pseudo approach brands like Acura employ where it applies brakes on the inner wheels to make the car turn.
Lexus did the proper and right way (albeit much more expensive way) of having motors on each driving wheel that provide extra torque to the outer wheel to make it spin faster in order to get the car to rotate quicker.
Anyway
Old 03-29-15, 10:35 PM
  #1027
FT2011
FT2011's Avatar
Lexus' own info shows the torque in reverse direction of travel under braking, they call it "coastal torque" supposedly, and it seems to be applied to the inner real wheel as well in the case of the RC-F too. What you describe happens once you get on the throttle, and all proper LSD's do that, not specific to Torsen or VTD. How is the reverse torque provided, that is what I am wondering.
Attached Thumbnails RC F automotive reviews thread-screen-shot-2015-03-30-at-1.27.54-am.png
Old 03-30-15, 01:44 AM
  #1028
Nights
Nights's Avatar
Australian comparo of the M4 and RCF.
http://www.drive.com.au/new-car-comp...25-1m5uft.html
Similar points to other reviews:
M4: Very fast but twitchy. More fun track car (as compared with RCF). Narrow power band and difficult to modulate, leading to being difficult to drive at the limit. Expensive. Interior rattles/trim issues.
RCF: Better sound. More livable as a daily driver. More progressive handling. Much cheaper than M4. Good performance. Thirsty.
Overall, in the video, they gave it to the RCF as a more well rounded car.
Old 03-30-15, 09:09 AM
  #1029
Motor
Motor's Avatar
German giant takes on Japanese newcomer in the battle for performance coupe bragging rights.
RC F wins.
Old 03-30-15, 01:38 PM
  #1030
redspencer
OG Member
redspencer's Avatar
I've also been wondering how the reverse torque is applied on the TVD as well. Unfortunately I have been unable to find any Lexus publication to provide further details. I can't imagine it would be good on the drivetrain or rear half shaft if the rotation of the torque was to go into reverse all of a sudden, even if for a brief moment.
I'm assuming that during the initial turn-in while/after braking, there is an eLSD effect with the rear brake being applied to the inner rear wheel in order to affect the cornering radius. The clutch packs of the TVD can then properly distribute torque to the outside rear wheel once the vehicle is ready to accelerate out of the corner beyond the apex. I'm able to duplicate this perceived effect with the combination of having an eLSD and an aftermarket LSD on my IS.
Old 03-30-15, 03:12 PM
  #1031
followtheF
followtheF's Avatar
Remember torque is a rotational force, not a rotational motion. So adding negative torque to the inside wheel will just cause that shaft to decelerate, not all of a sudden go backwards. Brakes are essentially negative torque if you want to think about it that way.
I'm assuming negative torque in the TVD is created by electronically "ungripping" the clutch plates. Ie slow the inside wheel not by braking, but by using that electronic motor to disengage some of the torque on the inside. With the diff transferring less torque to the inside wheel than it was before (ie negative torque) you get a yaw force rotating the car in the direction of the turn.
That being said, this is all a guess and a little more info from Lexus would be nice.
Old 03-30-15, 03:31 PM
  #1032
corradoMR2
The pursuit of F
corradoMR2's Avatar
Originally Posted by Motor
Best all-around pick for daily use! M4 they tested already had rattles probably due to the harsh ride.
Old 03-30-15, 06:05 PM
  #1033
05RollaXRS
05RollaXRS's Avatar
Old 04-02-15, 12:34 PM
  #1034
czar07
czar07's Avatar
Anyway
BMW M4 Versus Lexus RCF Drag Race | PistonHeadsTV - YouTube
Can you please provide more information on this.
Old 04-02-15, 05:15 PM
  #1035
05RollaXRS
05RollaXRS's Avatar
Which part? For Lexus? (see above for the brochure picture on TVD) or the Honda/Acura one? (can be found all over the internet).
Like this one for example:
"like Acura’s own Super Handling All-Wheel-Drive system — this is accomplished by simply braking the inside wheel while sending more power to the outside."
http://driving.ca/acura/rlx/reviews/...-hybrid-sh-awd
Quick Reply: RC F automotive reviews thread
