RC-F revs to just under 7500 rpm
Just under 7500 rpm (redline starts at 7300 rpm). Rev limiter might be exactly at 7500 rpm.
Although, the VQ engines sound thrashy, buzzy and generally grumpy at high revs, I am sure this V8 would be silky smooth and as the chief engineer has said it will get progressively high pitched and high strung as the revs rise (inspiration from the LFA).
Received 1,058 Likes
"The more you know..."
The RC F motor will actually shift at 7,200 RPM. The rev limiter will bounce at 7,300 RPM
See the motor actually rev limit here: http://instagram.com/p/jirrNKOFJ7/
For comparison sake, the IS F motor shifts at 6,700 RPM and bounces on the redline limiter of 6,800 RPM
Below is a snap of the RC F Gauge Red RPM needle pausing at 7,200 RPM
~ Joe Z
~ Joe Z
Redline clearly starts at 7300 rpm and following typical convention, it will definitely have an extra 100 - 150 rpm extra from where the redline starts so the rev limiter technically should be at the 7400 - 7450 rpm.
If you look at the picture I posted above, the rpm bar is one or two notches aft of where the redline starts.
~ Joe Z
~ Joe Z
Guest
Posts: n/a
Can't wait to hear it scream
Based on my own calculations, rev limiter is at 7400 - 7450 rpm (7300 rpm confirmed redline + the 100 to 150 rpm standard leeway to cut off) as opposed to 6800 rpm cut-off on the IS-F so 600 - 650 rpm difference for me.
How about this.. The IS F red line starts at 6,800 RPM.. The RC F red line starts at 7,300.
The difference is 500, doesn't matter how you do your math!!
Seriously, you post a lot of questionable findings.
~ Joe Z
I inaccurately thought the IS-F redline starts at 6700 rpm.
