Rev match is slow and not consistent
I can't predict when it will work like a charm or when the rev match flat out svck. The proper way it should work is when down shift with the paddle, the rpm should blip and match lower gear. Half the time I do that, the engine does not blip and instead it "catches" with the lower gear rpm and jerks. Gets annoying as heck. I never drive on eco btw. Seems better when I have trac off (normally i drive on normal mode). Am i missing something? Anyone else experience this?
Try braking harder.
At least that's what I experience when driving in auto either sport or sport+.
On freeway when you downshif to pass it never blips.
I don't always drive in manual. But I think you get the blip if it senses like you're going into a corner which is essentially hard braking. I think a certain amount of Gs registers/threshold and then it thinks you're downshifting and gives you that blip before a turn.
Try braking harder.
Try braking harder.
LRCSALES (02-21-17)
If your at low rpm it sometimes doesn't bleep the throttle. Or if your being really light on the gas. When i am driving aggressive it works perfect and is instant and when im cruising its smooth and shifts like butter. I love the zf8speed
theyre great too except you have an aisin.
Tech Info Resource
Who told you there is a revised software release for the gearbox? There is nothing in TIS about a transmission software update - I have a professional diagnostics subscription, so I can see all the updates.
Maybe the OP is referring to the ECU reflash for the fuel pump?
What I noted that you need to be at full operating temp.
Works Everytime in gears 1-5 in sport/sport+.
