Largest Rear Tire Size On Stock Wheels
So my tires are starting to wear down and I'm almost at 15k miles and I'm starting to have issues with traction. I'm thinking about putting some wider tires on the rear of the RCF, but how wide can I safely go without rubbing too much or putting too large of a tire for the wheel? For reference the stock Michelin PSS that came from factory are 275/35/19 and I was hoping to go either 295/30/19 or 305/30/19 also with Michelin PSS tires. My car is lowered on Swift Spec-R Springs and I have spacers as well (15mm). Has anyone done this, opinions?
I know for sure (confirmed by 3 separate major tire shops) that 305/30 would fit on STOCK height without any rub and 305/35 will rub. If you go 35 series, it will rub for sure when lowered
305 is the max that will fit safely on a 10' rim.
Stock rear is 275/35 not 275/40 as you stated
TruPlaya26 (01-29-17)
305/30 will fit for sure if you are stock height (which im doing in a month), but since you are lowered it will be tricky. Maybe they have a special calculator for you. They also have a policy if your tire rubs when installed and lowered to ground (not driving on it), you dont have to buy it.
For my first tire replacement, I definitely plan on going wider. I'm thinking 275 up front and 295 in the rears. I'm on stock rims. I know our stock tires are:
Front - 255/35 = 255*.35 = 89.25 mm * 2 = 178.5 mm = 7.02 inches + 19 inch rims = 26.02 inches wheel diameter.
Rear - 275/35 = 275*.35 = 96.25 mm * 2 = 192.5 mm = 7.58 inches + 19 inch rim = 26.58 inch wheel diameter
So If we go with 275 up front and 295 in rears. I assume 295 in rear should be 295/30 rather than 295/35 to keep to as close as stock wheel diameter as possible.
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
I thought smoked said the 305/30 would fit safely on the rear oem wheels, especially if the car hasn't been lowered?
I like this idea with going wider. I'm almost due for new tires too (rear ones).
But for safety reasons I'm changing all four to all seasons tires as I encounter 20 degree or below temperatures sometimes in the winter. If I just change the rears to all seasons and keep the OEM front Summer High Performance tires, then I'm asking for trouble risking loosing my tail breaking traction.
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
Edit:
As an example of the grip; I've hit 1.0g on the G Force meter in the car on a S-curve here at work while travelling 65 mph. I don't know how much more grip I could pull out of them because I don't want to end up in the ditch.
I'm running 265/285 Michelin Pilot Sport A/S3+ since I'm working in NC on a contract and my PSS wouldn't grip at temps below 40. I went back to Tampa for a couple of weeks over Xmas and I don't notice hardly any difference in grip between the 265/285 A/S3+ and the stock 255/275 PSS in hot temperatures. In cold temperatures there is a clear difference and the A/S3+ are far superior. You "might" notice a difference if you run the car at the track. But on the street the difference is so minor that I will run A/S3+ all year from now on. They should also last twice as long on the tread wear. I'll keep some PSS on my spare set of rims if I decide to start tracking the car. YMMV
Edit:
Edit:
I only got 10000 miles out of them, even though they are rated at 500 threadwear. I will admit I did at least 50 runs on the drag strip and drive pretty hard daily. 3400 lbs 370z curb weight. Only con is they dont make it larger than 285/35
The current 275/35 PSS on the RCF, the cars breaks traction in second gear WOT on a hot day. Its inefficient and not fun. That's why many want to increase to the largest size possible. Going 30mm larger should help significantly. I'm also looking at Bridgestone RE11, as they are grippier and cheaper
I had the A/S 3 on my 370z when it first came out and its a pretty sticky tire on the dragway too. I did my best time with it, with a mild burnout. If you read some reviews on tirerack, under extreme cold temp with snow, it doesnt grip as well compared to other brands. In the rain its great, on the dry it grips close to the PSS
YMMV, maybe road conditions (oil, gravel, etc) or extreme heat (100+)? I know the roads in Socal get a lot of oil built up due to little rain.
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
Stock Front: 255/35
Stock Rear: 275/35
New Front: 275/30
New rear: 295/30
