Rcf TSIB
Rcf TSIB
Taking the Rcf in for TSIB next week. Just want to make sure I'm not missing anything
-less dusty brake pads
-reflash fuel pump
anything else in missing?
-reflash fuel pump
Im going to let them replace mine then ill quickly remove it and put on endless pads and have the stock ones as spares.
the ones they are replacing takes away noise but supposedly less performance. Endless pads are about 900 for front and rear. they are aftermarket but why not get free pads if you can.
if its tsib why wont they do it since is well known issue and well documented? I don't have the fuel pump hissing but why not have it reflashed since its a known problem and im there anyways.
I've been getting a lot more squeal in this colder weather during light braking. It may be time to change pads. I wasn't having issues before, but now that I am I don't like it. They seem to squeal just when I don't want them too.
I'll do some research on it first though. I'm not likely going to get the freebies from the dealer. I need pads that can stop the car from 170mph without a problem. The factory OEM pads performed to my liking for that. I don't know about their alternate pads. Plus, I hear the alternate pads still create a lot of dust. So if I'm going to change the type of pad for the squeal then I may as well nip that in the bud at the same time.
Guys sorry to bump, but did i read somewhere there is a tsib for something to do with the rear axle and it being able to rust easily or something, really would like an answer & thanks y'all so much!!!
