Front Curb sensor
I have this one:
http://www.curb-alert.com/
I haven't quite decided where to mount it yet, I had one on my 2012 Camaro and it worked great. I would like to put it at the bottom center behind the grille, but I do not know if the grille will interfere with it, if it does I will have to mount it underneath the fascia.
I put the buzzer in the glove box on the Camaro, will probably do the same with the RCF.
The best part about this is that it is free.
yeah I will get around to it when I go on vacation in August.. need to do this and install the led light replacements I bought for the lower rear reflectors. just don't have the time.
Beatsonic will be selling front camera switch in a few months. I have similar setup but I have to switch to A/V mode to see my front camera. This switch will let you see the image when you're at parking speed or pressing external switch.
I also had Curb alert but it wasn't very good, I kept getting false alert.
http://www.beatsonicusa.com/cs5ep.html
I've been curious to know if additional factory front sensors could be installed on the RCF and wired in series to the existing ones.. while the computer would not be able to determine if it is a corner or the front causing the alert, you would still get an alert. in theory if you wire a left and right center to the left and right corners then the dash alert would light up both corners which would indicate that it is the front sensors being tripped. Where if it was the original corner sensors you would only get that corner.
might be worth some testing if I have time.
Supercharged!
I had a curb alert on my Camaro and never had an issue. perhaps yours wasn't adjusted correctly.
The sensor also does not work with parking blocks that are offset, I found about half of parking spaces have the offset. Camera was better fit for this situation.
