Just had the 5k service done and active wing repair
Did anyone else see a noticeable increase in power after receiving their car back after this service? When I received my car back it felt a lot stronger than it did when I dropped it off. I do not think this is due to it being gone for a day and driving my other car as I was driving my S/c 1969 Mustang around. Just curious if it was all in my head or others noticed the same thing
if they disconnected the battery they yeah it's possible, the computer would have been reset.
"The ECU monitors the mass air flow meter (MAF), the oxygen sensors (O2), the knock sensor, the idle speed, and a host of other sensors. If you drive agressively and your fuel octane is low the ECU will "learn" a less agressive timing curve than the base factory setting. If you change the intake to allow more air flow the O2 sensors will signal a leaner condition again followed by the ECU adjusting. There are other conditions but suffice to say that these are all deviations from the "BASE" factory programming. Disconnecting power from the ECU erases these changes and returns to the factory settings. This may produce more power. As Lou stated the ECU will relearn over a few days of driving." - quoted from member Jbrady
Your #1 Lexus Vendor
Theres a thread like this on the ISF forum. If they reset the battery, it may feel like it, since the ECU resets and is learning. Just like stated above.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
-Josh
-Josh
No, but they did remove the "Type R" sticker I put on there
Did they add some performance stickers?
Understanding what the 5K service entails, what would be the logic behind why you would even begin to ask this question? Just curious.
