Largest tire size on stock or aftermarket wheel
The 275s are too skinny. What's the largest size increase on stock 10' wheel or widest tire anyone is running on aftermarket wheel without rubbing?
I was going to ask the same thing-
traction is definitely an issue. Has anyone gone with wider tires up front as well? I'm not sure it would change the balance of the car if you went that much wider in the rear and didn't widen the front as well.
It looks like the factory sizes are stretched on the rims, so I'd hopeful you can get some wider rubber on there.
