New front brake pads..
So my RCF was in for the 20,000km service.. service advisor told me that I need new brakes pads, and he said there is a warranty claim for new ones for free.
so now I got new front pads, not sure if they are different or the same just new ones.
I will report back in the next week or so if they still squeak. Anyway, you gota love new free pads
Check and get back to us.
My original pads WERE ABSOLUTELY HORRIBLE!!! And I do not buy the "these a performance pads and they squeak" explanation.
performance car, performance pads, associated noises. lexus buyers truly. smh you bought the wrong car if you want your grandpa's LS silence. i feel bad for F engineers. you'd NEVER hear BMW M owners or 911 drivers being so vocal over such non-issues.
It's a fact. That you don't like that is a different matter. Go to a driving/racing school and you better wear earplugs. I personally think Lexus got it just right: the brakes are phenomenal on this car. But most importantly, the FEEL is too. With only mild squealing. My car is not bad at all. What I'm not crazy about is the insane amount of dust they generate, but that's another side-effect of awesome braking power. And many of us decided to live with that and keep one of the most enduring features of this car. To each his own though. The good news is Lexus now gives the option to those not-so-sporting drivers to swap them for free. Can't argue with that. Good luck.
Guys...I'm not exaggerating or looking for something to complain about....the breaks on my car were 100% embarrassing and absolutely pathetic sounding. It was just way too ridiculous to listen to, so I had lexus change them for their substitute. The dust is now basically non-existent and the squeal is something that you can easily deal with....and the performance seems to be just as good as the previous pads, however it may make a difference on the track.
Now a solution, which could be partial, but would surely reduce squealing a great deal: Noticed the pads on the RCF are not chamfered at the leading edges. Most manufacturers do that, but high-performance/racing pads usually not, to maximize swept (surface) area. So not surprised they're not on the RC-F. All you need is a small angle so pad and rotors are not at 90º, which promotes squealing. This is only necessary at the LEADING edge, so in case of the front calipers, the lower part of each pad. But you'd have to remove them and grind them at a 30º angle or so, but don't go near the backing plate. You can google pads and see how most come from the factory. Or if you don't care about losing a bit of performance and feel, just ask your dealer for the free ceramic pads and call it a day. Hope this helps.
In searching other forums I found there are some interesting reviews on RB's ET500 for luxurious cars like Mercedes, and spirited driving like in EVO and GTR communities.
Racing Brake makes me happy
http://mbworld.org/forums/sl-class-r...ml#post5939978
Racing Brakes ET500 installed
http://www.gtrlife.com/forums/forum/180-brakes/
I heard Mike from Fig Eng'g is working with RB for RCF pads.
The Maker
Hi guys, we are very close to offering our front and rear pad set that should resolve this issue. Test pads were fitted yesterday in fact in addition to our 2P rotors.
Brake squeal is likely one the largest problems with any high performance brake system but there a number of reasons and it is not always a matter of lead on in the pad. This aids in the transition but more than likely it has to do with the surface condition of the rotor and the bed-in of the pad on the face of the rotor. You have to picture it as 2 surfaces interlocking and making and braking contact at a low level. If you operate the pad below its target temperature it will not expand enough to let the rotor material "in" and it will skip across the top. This skimming causes further rounding of the rotor and the pad leading to resonance in the pad (movement at a frequency of the skipping) causing the noise. Then we get back to dust as the 2 materials will interact and the pad material will separate. So what do you do.....?
Probably the easiest way to remedy the squeal as stated is the re-bedding of the pads. That is to get them hot enough and to apply enough pressure to reshape the interface between the two components. But longer term, if you are just not a heavy braker and I mean someone that finds the bottom of the pedal occasionally, the milder pad is likely more suited for your style of driving. The impact on performance is subjective as there is so much on the table with larger brakes. The RB Performance pads for the street should be an excellent alternative as then are intended for lower temperature stopping and the smaller granularity means that there is less material sacrificed in the process all while providing the same pedal feel of the 60% or less that most street drivers are using. The downside is they are not track rated, which does not seem to be a factor here.
Small changes to the backing plate and we should be good to go in a few more weeks. We will keep you posted. We had the application sorted based on the FSMI backing plate number, but of course Lexus made a few slight changes that we need to account for in the process of releasing these.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
