Any way to set Sport+ and trac off as the default?
I am trying to find a way to have the car default to sport+ and trac off as the default, rather than having to change these every time i start the car. Wishful thinking I'm pretty sure, but maybe there is a way...
No, there is not a way to do that AFIK. I believe he current default mode is to get the car's fuel efficiency numbers, probably, keeping the ULEV, if any, intact and.to comply with corporate "wisdom".
Lol, you are like me. I always intend to be in Sport + just because I think the car better in that mode. I do get the little or pause (which I still believe is an 8 speed tranny downshift issue) going around corners in normal mode. In fact, normal mode can be very annoying due to very unaggressive mapping and 8 speed tranny.
Received 1,058 Likes
Anyone else notice that on the freeway Sport S+ doesn't shift past 6th gear ???
I found using Sport S solved that issue...
Sport S+ in Manual Mode is fun, but you have to switch back to Sport S if you want to use your other two gears..
Joe Z
Joe Z
I have seen mine go to 7 a couple times at about 80 mph on flat level highway, but it seems to be the exception rather that the rule.
