RCF out of the box suspension adjustment
For those who wish to lower their RCF on adjustable coilovers, is there any sort of factory adjustability on the suspension like camber? Or is it the same story like the ISF where there's none of the above so you have to call FIGS to do it right?
Thanks.
Thanks.
I have the Figs set up and his bushings kit. Plenty of others have gone low w/o buying the parts..... Just depends on how you like to do your builds. I believe RastaRacer did the same as myself.
I tend to do things in the top x% percentile as I find "plenty of others" to be not worth getting involved. For example, when ordering wheels, I'll be working closely with the HRE rep to get the perfect fitment so that "rubs when lowered" or "only on certain bumps" or "stretched look" is a non-factor. That hub-centricity, strong and light, doesn't vibrate in the rain, accepts factory center caps and lugs is in the field of play.
Thanks for the insight!
