RC F Aftermarket Wheels (Merged Threads)
Old 11-17-15, 07:04 PM
  #61
jsmacks
jsmacks's Avatar
http://blog-int.kwautomotive.net/bor...or-lexus-rc-f/
Hmm.. still a couple of weeks left before ordering the RSRs.. 4-6 weeks on the Vossens after the down payment today...
Decisions decisions..
Vossen VPS-314 - 9/+25 / 10.5/+25 - gloss gunmetal - ordered today.
FIGS RC-F, RC350, 3IS, 4GS Essential Kit for lowering - ordered today
- Front LCA Bushing Pressed into OE Bracket: Yes (refurbushed)
- Front LCA Bushing Type: Standard (no offset)
- Front LCA Bushing Duro: High Performance 90 Duro
- Rear Upper Arm Bushing: SuperPro Polyurethane
Still debating on tire type/size. Now I'm wondering about the coilovers..
Old 11-17-15, 07:22 PM
  #62
FR500GT
FR500GT's Avatar
Originally Posted by ROK
I've still yet to see even a single set of properly fitting wheels here. I'm just trying to be honest and helpful. No ill will.
For example, HRE recommends 255/30/20 and 295/30/20 on 9 and 10.5" wide wheels for the common plus 1 from OEM sized RCF wheel buyer. The more rubber you can lay down, within reason, is always a good thing per motorsport. HRE measurements are usually spot on.
Next, a properly fitting wheel and tire package should not rub lowered let alone at stock height. It should not require you to go skinny on the tires or stretched in any way, shape or form. So the only way to meet these parameters is to go custom. I've yet to see a quality wheel vendor make a set bespoke to the RCF which makes complete sense. Volk. No. BBS. No (non-factory). OZ. No. Work. No. Never. Why? Because there isn't enough volume and likely never will be like the congested BMW M3 scene.
If you really want to do it right going the lowered route, you have to look into FIGS suspension parts as the RCF offers zero adjustability unlike the M3.
So here's a sample, do-it-right checklist the ROK way:
-Custom spec 20" 6061-T6 forged wheels (e.g. HRE, Forgeline, or if cast, Work)
-FIGS lowering suspension components
-Quality rubber (as wide or wider than stock)
-Quality adjustable coilovers (e.g. KWv3s just released)
I conjecture, strongly, that anything less is worse than stock (i.e. ghetto fab).
I hope this helps gets the brain juices flowing toward the right direction.
I have a few things in mind if I do in fact jump into an RCF in the next month or so. Something meaty
Old 11-18-15, 08:08 AM
  #63
JB5674
JB5674's Avatar
https://www.clublexus.com/forums/rc-...coilovers.html
https://www.clublexus.com/forums/rc-...r-the-rcf.html
regarding coilovers - please take a read
Old 11-22-15, 10:07 PM
  #64
jsmacks
jsmacks's Avatar
285/30-20 295/30-20 Difference
Diameter inches (mm) 26.73 (679) 26.97 (685) 0.24 (6) 0.9%
Width inches (mm) 11.22 (285) 11.61 (295) 0.39 (10) 3.5%
Circum. inches (mm) 83.98 (2133.14) 84.72 (2151.99) 0.74 (18.85) 0.9%
Sidewall Height inches (mm) 3.37 (85.5) 3.48 (88.5) 0.12 (3) 3.5%
For only 1/4" difference in diameter, it does look like it makes sense to bump up to 295.. only problem is the more limited availability between the brands. You're pretty much down to Pirelli P-Zero and Michelin Pilot Super Sport. I was leaning towards the Hankook V12s..
EDIT: Thanks for the push. 295 SS's it is..
Old 11-23-15, 07:54 PM
  #65
DjRiDe
DjRiDe's Avatar
Vossen x RCF
Attached Thumbnails RC F Aftermarket Wheels (Merged Threads)-lexus_rcf_vps-310_500.jpg   RC F Aftermarket Wheels (Merged Threads)-lexus_rcf_vfs2_6d8.jpg   RC F Aftermarket Wheels (Merged Threads)-lexus_rcf_vps-308_0de.jpg   RC F Aftermarket Wheels (Merged Threads)-lexus_rcf_vps-302_6d1.jpg
Old 11-27-15, 06:25 AM
  #66
spmcg
spmcg's Avatar
PUR RS07. Check them out. http://www.purwheels.com/upload/sets...urrs07ddt1.jpg
Old 11-27-15, 08:48 AM
  #67
4everkidd
4everkidd's Avatar
I'm really not sure about that rear diffuser.
Old 11-27-15, 11:33 AM
  #68
FR500GT
FR500GT's Avatar
Those of you running 11" wide rears, what offset are you running?
Old 11-27-15, 01:21 PM
  #69
jsmacks
jsmacks's Avatar
FWIW, I called Velgen directly to ask about the tire size on this exact car.. and they report that they're 245/275..
Originally Posted by Velgen
[CENTER]Customer's Lexus RCF on Velgen Wheels
VMB7 Matte Gunmetal
Front: 20x9 +20
Rear: 20x10.5 +25
Old 12-07-15, 06:54 PM
  #70
jsmacks
jsmacks's Avatar
Final order in place:
255/30 20 - 9" +25
295/30 20 - 11" +25
Hoping and praying that they fit..
Old 12-07-15, 08:22 PM
  #71
johnnyreb
johnnyreb's Avatar
255/30 20 - 9.5" +25
295/30 20 - 11" +25
GL js & post some pics as SOON as you get'em on
Old 12-07-15, 08:27 PM
  #72
JB5674
JB5674's Avatar
anyone willing to share their alignment specs?
Old 12-07-15, 10:12 PM
  #73
jsmacks
jsmacks's Avatar
Originally Posted by boostedGS
Thanks! I'll see what option I go with for wheel set, I guess high offset on 10.5" or so with 285 or 295's would be nice, if it fits, but I guess that means I can't rock my Meisters. But I'll see whats up after I test fit, hopefully I can still rock 275's on 11" +24.
Wait.. WHAT? Are you saying that the clearance is so tight that wider wheels will interfere with aftermarket exhaust?? I'd love some clarification on the statement!
Comparing stock tire specs to the 295/30 20 doesn't look like it's all that radical. 7/8" wider and less than half an inch taller.
PS. I mistyped earlier. 9" +25 on the fronts, not 9.5".
Old 12-08-15, 03:39 AM
  #74
JT2MA71
JT2MA71's Avatar
Received 1,513 Likes on 656 Posts
Comparing stock tire specs to the 295/30 20 doesn't look like it's all that radical. 3/4" wider and less than half an inch taller.
I think he meant Work Meisters
I ordered some custom one-piece forged wheels, specs are 19x10 fronts and 19x12 rears.. Can't wait to get them and see how they fit!
Old 12-08-15, 11:40 AM
  #75
jspecvtec
jspecvtec's Avatar
Wow nice....so wide!
Quick Reply: RC F Aftermarket Wheels (Merged Threads)
