Bought a thing
Your #1 Lexus Vendor
Sweeeet!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Stupid mobile app is TERRIBLE on iOS 10, I hope they fix it soon (and the website just fails to upload on mobile)
My thoughts:
After:
My thoughts:
- Tip in throttle is much better sensitivity wise.
- Mild increase in noise (OEM was actually really well designed)
- Power feels better at higher range, not a HUGE difference but enough to know that little extra is there in the higher MPH/RPM range.
- Worth the price!
- Stupid hose clamps are not labeled, they are directional logo wise and the clamps are not the easiest to use (they are already loosened all the way from HPS, but they are still a PITA to move when you get the coupler on, I recommend wetting the coupler with water or something to rotate them BEFORE putting them on and on the TB/MAFS)
After:
I recently installed this pipe on my car as well. It's fairly nice, I just with the polished they inside. I will polish it myself one day when I have time.
I noticed this myself and wondered why they didn't take the time to polish the inside, it can only help (unless the MAFS hates it)
Also, what are the main differences between this and the Takeda. Is it only one uses the factory air box and filter and the other uses the cone type filter or one is better sound, power, etc. than the other?
Did you notice any mpg improvement? Another CL member installed the Takeda CAI and had a 2-3 mpg improvement.
I didn't like the idea of the "CAI" because it's just a ram air with a heat shield. The stock intake is what makes it a cold air intake as they re-use it whereas this way you're just sticking with the stock box (and that looks pretty well engineered including the connection to exterior air).
I already noticed my MPG meter staying on the high side of 20 now more often especially on low throttle (that is, when I have my foot out of it).
Thanks for the answer. I haven't modded my intake yet but have been looking at the options out there. I agree that the stock setup whereas the air enters thru the grill then is directed up and into the air box looks to be solid to me. I'm wondering how much colder(denser) you could get than coming right in the front of the vehicle. I'll admit though I know nothing about intakes so others freely chime in, I'm open for the education.
I've never agreed with pulling air from the engine bay with a conical filter, so I avoid it.
I would appreciate knowing how this differs from the OEM intake. Is it just a smooth walled pipe to smooth out air flow? Looking at the pictures leaves me wondering how it is better than the OEM. Thanks.
The spots for the air intake microphone and such seemed to be much smoother transitioning versus OEMs hard plastic too.
Also, no bendable accordion section which can cause turbulence in air flow
